Staging: ft1000: Remove parentheses around right side an assignment
Author: Haneen Mohammed <hamohammed.sa@gmail.com>
Parentheses are not needed around the right hand side of an assignment.
This patch remove parenthese of such occurenses. Issue was detected and
solved using the following coccinelle script:
@rule1@
identifier x, y, z;
expression E1, E2;
x = (y == z);
x = (E1 == E2);
 x =
Signed-off-by: Haneen Mohammed
 drivers/staging/ft1000/ft1000-pcmcia/ft1000_dnld.c  | 4 ++--
 drivers/staging/ft1000/ft1000-pcmcia/ft1000_hw.c    | 4 ++--
 drivers/staging/ft1000/ft1000-usb/ft1000_debug.c    | 2 +-
 drivers/staging/ft1000/ft1000-usb/ft1000_download.c | 4 ++--
 4 files changed, 7 insertions(+), 7 deletions(-)
diff --git a/drivers/staging/ft1000/ft1000-pcmcia/ft1000_dnld.c b/drivers/staging/ft1000/ft1000-pcmcia/ft1000_dnld.c
index cbf59ab..ddb7466 100644
--- a/drivers/staging/ft1000/ft1000-pcmcia/ft1000_dnld.c
+++ b/drivers/staging/ft1000/ft1000-pcmcia/ft1000_dnld.c
@@ -276,8 +276,8 @@ u16 hdr_checksum(struct pseudo_hdr *pHdr)
 	u16 *usPtr = (u16 *)pHdr;
 	u16 chksum;
-	chksum = ((((((usPtr[0] ^ usPtr[1]) ^ usPtr[2]) ^ usPtr[3]) ^
-		    usPtr[4]) ^ usPtr[5]) ^ usPtr[6]);
+	chksum = (((((usPtr[0] ^ usPtr[1]) ^ usPtr[2]) ^ usPtr[3]) ^
+		    usPtr[4]) ^ usPtr[5]) ^ usPtr[6];
 	return chksum;
diff --git a/drivers/staging/ft1000/ft1000-pcmcia/ft1000_hw.c b/drivers/staging/ft1000/ft1000-pcmcia/ft1000_hw.c
index e5890db..0afe37f1 100644
--- a/drivers/staging/ft1000/ft1000-pcmcia/ft1000_hw.c
+++ b/drivers/staging/ft1000/ft1000-pcmcia/ft1000_hw.c
@@ -1295,9 +1295,9 @@ static int ft1000_parse_dpram_msg(struct net_device *dev)
 					  2) >> 8) & 0xff;
 			} else {
 				portid =
-					(ft1000_read_dpram_mag_16
+					ft1000_read_dpram_mag_16
 					 (dev, FT1000_MAG_PORT_ID,
-					  FT1000_MAG_PORT_ID_INDX) & 0xff);
+					  FT1000_MAG_PORT_ID_INDX) & 0xff;
 			pr_debug("DSP_QID = 0x%x\n", portid);
diff --git a/drivers/staging/ft1000/ft1000-usb/ft1000_debug.c b/drivers/staging/ft1000/ft1000-usb/ft1000_debug.c
index b427825..2d758fb 100644
--- a/drivers/staging/ft1000/ft1000-usb/ft1000_debug.c
+++ b/drivers/staging/ft1000/ft1000-usb/ft1000_debug.c
@@ -301,7 +301,7 @@ static int ft1000_open(struct inode *inode, struct file *file)
 	struct ft1000_usb *dev = (struct ft1000_usb *)inode->i_private;
 	int i, num;
-	num = (MINOR(inode->i_rdev) & 0xf);
+	num = MINOR(inode->i_rdev) & 0xf;
 	pr_debug("minor number=%d\n", num);
 	info = file->private_data = netdev_priv(dev->net);
diff --git a/drivers/staging/ft1000/ft1000-usb/ft1000_download.c b/drivers/staging/ft1000/ft1000-usb/ft1000_download.c
index 800450f..5def347 100644
--- a/drivers/staging/ft1000/ft1000-usb/ft1000_download.c
+++ b/drivers/staging/ft1000/ft1000-usb/ft1000_download.c
@@ -368,8 +368,8 @@ static u16 hdr_checksum(struct pseudo_hdr *pHdr)
 	u16   chksum;
 	return chksum;
BtrLinux
Privacy Overview
