staging: ft1000: ft1000-usb: adjust function arguments
Author: Aya Mahfouz <mahfouz.saif.elyazal@gmail.com>
Handles the following issues:
Removing extra parentheses around function arguments,
Removing unnecessary pointer to pointer cast.
Issues were detected using the following coccinelle script:
expression e;
type t;
identifier f;
f(...,
-(t *)
e
expression e;
identifier f;
f(...,
e
expression e;
identifier f;
f(...,
e
Parentheses removal were left to the script. However, handling pointer
casts were done manually because not all replacements generated by the
script were suitable. In general, the following cases were discarded:
pointer casts in macros,
pointer casts on function arguments in the form of:
since both cases generated compilation warnings.
Signed-off-by: Aya Mahfouz
 drivers/staging/ft1000/ft1000-usb/ft1000_debug.c | 8 ++++----
 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/staging/ft1000/ft1000-usb/ft1000_debug.c b/drivers/staging/ft1000/ft1000-usb/ft1000_debug.c
index 0f776d0..7138523 100644
--- a/drivers/staging/ft1000/ft1000-usb/ft1000_debug.c
+++ b/drivers/staging/ft1000/ft1000-usb/ft1000_debug.c
@@ -190,7 +190,7 @@ int ft1000_create_dev(struct ft1000_usb *dev)
 	tmp->dent = dir;
 	tmp->file = file;
 	tmp->int_number = dev->CardNumber;
-	list_add(&(tmp->list), &(dev->nodes.list));
+	list_add(&tmp->list, &dev->nodes.list);
 	pr_debug("registered debugfs directory \"%s\"\n", dev->DeviceName);
@@ -477,14 +477,14 @@ static long ft1000_ioctl(struct file *file, unsigned int command,
 		/* Connect Message */
 		pr_debug("IOCTL_FT1000_CONNECT\n");
 		ConnectionMsg[79] = 0xfc;
-		result = card_send_command(ft1000dev, (unsigned short *)ConnectionMsg, 0x4c);
+		result = card_send_command(ft1000dev, ConnectionMsg, 0x4c);
 		break;
 	case IOCTL_DISCONNECT:
 		/* Disconnect Message */
 		pr_debug("IOCTL_FT1000_DISCONNECT\n");
 		ConnectionMsg[79] = 0xfd;
 		break;
 	case IOCTL_GET_DSP_STAT_CMD:
 		/* pr_debug("IOCTL_FT1000_GET_DSP_STAT\n"); */
@@ -642,7 +642,7 @@ static long ft1000_ioctl(struct file *file, unsigned int command,
 						pmsg++;
 						ppseudo_hdr = (struct pseudo_hdr *)pmsg;
-						result = card_send_command(ft1000dev, (unsigned short *)dpram_data, total_len+2);
+						result = card_send_command(ft1000dev, dpram_data, total_len+2);
 						ft1000dev->app_info[app_index].nTxMsg++;
BtrLinux
Privacy Overview
