Staging: fsl-mc: Replace pr_err with dev_err
Author: Bhumika Goyal <bhumirks@gmail.com>
This patch replaces pr_err calls with dev_err when the device structure
is available as dev_* prints identifying information about the struct device.
Done using coccinelle:
@r exists@
identifier f, s;
identifier x;
position p;
f(...,struct s *x,...) {
when != x == NULL
\(pr_err@p\|pr_debug@p\|pr_info\)(...);
@r2@
identifier fld2;
identifier r.s;
struct s {
        struct device *fld2;
identifier r.x,r2.fld2;
position r.p;
-pr_err@p
+dev_err
+ &x->fld2,
- pr_debug@p
+ dev_dbg
+ &x->fld2,
- pr_info@p
+ dev_info
+ &x->fld2,
Signed-off-by: Bhumika Goyal
 drivers/staging/fsl-mc/bus/mc-bus.c | 5 +++--
 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/drivers/staging/fsl-mc/bus/mc-bus.c b/drivers/staging/fsl-mc/bus/mc-bus.c
index 5958e0f..9f77c37b 100644
--- a/drivers/staging/fsl-mc/bus/mc-bus.c
+++ b/drivers/staging/fsl-mc/bus/mc-bus.c
@@ -260,14 +260,15 @@ static int get_dprc_icid(struct fsl_mc_io *mc_io,
 	error = dprc_open(mc_io, 0, container_id, &dprc_handle);
 	if (error < 0) {
-		pr_err("dprc_open() failed: %d\n", error);
+		dev_err(&mc_io->dev, "dprc_open() failed: %d\n", error);
 		return error;
 	memset(&attr, 0, sizeof(attr));
 	error = dprc_get_attributes(mc_io, 0, dprc_handle, &attr);
 	if (error < 0) {
-		pr_err("dprc_get_attributes() failed: %d\n", error);
+		dev_err(&mc_io->dev, "dprc_get_attributes() failed: %d\n",
+			error);
 		goto common_cleanup;
BtrLinux
Privacy Overview
