Staging: fsl-mc: Replace pr_debug with dev_dbg
Author: Bhumika Goyal <bhumirks@gmail.com>
This patch replaces pr_debug calls with dev_dbg when the device structure
is available as dev_* prints identifying information about the struct
device.
Done using coccinelle:
@r exists@
identifier f, s;
identifier x;
position p;
f(...,struct s *x,...) {
when != x == NULL
\(pr_err@p\|pr_debug@p\|pr_info\)(...);
@r2@
identifier fld2;
identifier r.s;
struct s {
        struct device *fld2;
identifier r.x,r2.fld2;
position r.p;
-pr_err@p
+dev_err
+ &x->fld2,
- pr_debug@p
+ dev_dbg
+ &x->fld2,
- pr_info@p
+ dev_info
+ &x->fld2,
Signed-off-by: Bhumika Goyal
 drivers/staging/fsl-mc/bus/mc-sys.c | 9 ++++++---
 1 file changed, 6 insertions(+), 3 deletions(-)
diff --git a/drivers/staging/fsl-mc/bus/mc-sys.c b/drivers/staging/fsl-mc/bus/mc-sys.c
index 6e14892..8101c46 100644
--- a/drivers/staging/fsl-mc/bus/mc-sys.c
+++ b/drivers/staging/fsl-mc/bus/mc-sys.c
@@ -328,7 +328,8 @@ static int mc_polling_wait_preemptible(struct fsl_mc_io *mc_io,
 			     MC_CMD_COMPLETION_POLLING_MAX_SLEEP_USECS);
 		if (time_after_eq(jiffies, jiffies_until_timeout)) {
-			pr_debug("MC command timed out (portal: %#llx, obj handle: %#x, command: %#x)\n",
+			dev_dbg(&mc_io->dev,
+				"MC command timed out (portal: %#llx, obj handle: %#x, command: %#x)\n",
 				 mc_io->portal_phys_addr,
 				 (unsigned int)
 					MC_CMD_HDR_READ_TOKEN(cmd->header),
@@ -369,7 +370,8 @@ static int mc_polling_wait_atomic(struct fsl_mc_io *mc_io,
 		udelay(MC_CMD_COMPLETION_POLLING_MAX_SLEEP_USECS);
 		timeout_usecs -= MC_CMD_COMPLETION_POLLING_MAX_SLEEP_USECS;
 		if (timeout_usecs == 0) {
 				 (unsigned int)
@@ -424,7 +426,8 @@ int mc_send_command(struct fsl_mc_io *mc_io, struct mc_command *cmd)
 		goto common_exit;
 	if (status != MC_CMD_STATUS_OK) {
-		pr_debug("MC command failed: portal: %#llx, obj handle: %#x, command: %#x, status: %s (%#x)\n",
+			"MC command failed: portal: %#llx, obj handle: %#x, command: %#x, status: %s (%#x)\n",
 			 (unsigned int)MC_CMD_HDR_READ_TOKEN(cmd->header),
 			 (unsigned int)MC_CMD_HDR_READ_CMDID(cmd->header),
BtrLinux
Privacy Overview
