staging: fsl-mc: Remove unneeded else following a return
Author: Janani Ravichandran <janani.rvchndrn@gmail.com>
Remove unnecessary else when there is a return statement in the
corresponding if block. Coccinelle patch used:
@rule1@
expression e1;
if (e1) { ... return ...; }
- else{
@rule2@
expression e2;
statement s1;
if(e2) { ... return ...; }
- else
s1
Signed-off-by: Janani Ravichandran
drivers/staging/fsl-mc/bus/mc-bus.c | 3 +--
1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/staging/fsl-mc/bus/mc-bus.c b/drivers/staging/fsl-mc/bus/mc-bus.c
index c42bfac..5958e0f 100644
--- a/drivers/staging/fsl-mc/bus/mc-bus.c
+++ b/drivers/staging/fsl-mc/bus/mc-bus.c
@@ -248,8 +248,7 @@ static bool fsl_mc_is_root_dprc(struct device *dev)
fsl_mc_get_root_dprc(dev, &root_dprc_dev);
if (!root_dprc_dev)
return false;
- else
- return dev == root_dprc_dev;
+ return dev == root_dprc_dev;
static int get_dprc_icid(struct fsl_mc_io *mc_io, |
if (!root_dprc_dev)
return false;
- else
