staging: fsl-mc: get rid of mutex_locked variables
Author: Cihangir Akturk <cakturk@gmail.com>
Remove mutex_locked variables which are used to determine whether mutex is
locked, instead add another label to unlock mutex on premature exits due to
an error.
This patch also addresses the folowing warnings reported by coccinelle:
drivers/staging/fsl-mc/bus/mc-allocator.c:237:1-7: preceding lock on line 204
drivers/staging/fsl-mc/bus/mc-allocator.c:89:1-7: preceding lock on line 57
drivers/staging/fsl-mc/bus/mc-allocator.c:157:1-7: preceding lock on line 124
Signed-off-by: Cihangir Akturk
 drivers/staging/fsl-mc/bus/mc-allocator.c | 61 ++++++++++++-------------------
 1 file changed, 24 insertions(+), 37 deletions(-)
diff --git a/drivers/staging/fsl-mc/bus/mc-allocator.c b/drivers/staging/fsl-mc/bus/mc-allocator.c
index 86f8543..bdb4b0e 100644
--- a/drivers/staging/fsl-mc/bus/mc-allocator.c
+++ b/drivers/staging/fsl-mc/bus/mc-allocator.c
@@ -39,7 +39,6 @@ static int __must_check fsl_mc_resource_pool_add_device(struct fsl_mc_bus
 	struct fsl_mc_resource *resource;
 	struct fsl_mc_device *mc_bus_dev = &mc_bus->mc_dev;
 	int error = -EINVAL;
-	bool mutex_locked = false;
 	if (WARN_ON(pool_type < 0 || pool_type >= FSL_MC_NUM_POOL_TYPES))
 		goto out;
@@ -55,13 +54,12 @@ static int __must_check fsl_mc_resource_pool_add_device(struct fsl_mc_bus
 		goto out;
 	mutex_lock(&res_pool->mutex);
-	mutex_locked = true;
 	if (WARN_ON(res_pool->max_count < 0))
-		goto out;
+		goto out_unlock;
 	if (WARN_ON(res_pool->free_count < 0 ||
 		    res_pool->free_count > res_pool->max_count))
-		goto out;
+		goto out_unlock;
 	resource = devm_kzalloc(&mc_bus_dev->dev, sizeof(*resource),
 				GFP_KERNEL);
@@ -69,7 +67,7 @@ static int __must_check fsl_mc_resource_pool_add_device(struct fsl_mc_bus
 		error = -ENOMEM;
 		dev_err(&mc_bus_dev->dev,
 			"Failed to allocate memory for fsl_mc_resource\n");
-		goto out;
+		goto out_unlock;
 	resource->type = pool_type;
@@ -82,10 +80,9 @@ static int __must_check fsl_mc_resource_pool_add_device(struct fsl_mc_bus
 	res_pool->free_count++;
 	res_pool->max_count++;
 	error = 0;
+out_unlock:
+	mutex_unlock(&res_pool->mutex);
 out:
-	if (mutex_locked)
-		mutex_unlock(&res_pool->mutex);
 	return error;
@@ -106,7 +103,6 @@ static int __must_check fsl_mc_resource_pool_remove_device(struct fsl_mc_device
 	struct fsl_mc_resource_pool *res_pool;
 	if (WARN_ON(!FSL_MC_IS_ALLOCATABLE(mc_dev->obj_desc.type)))
 		goto out;
@@ -122,13 +118,12 @@ static int __must_check fsl_mc_resource_pool_remove_device(struct fsl_mc_device
 		goto out;
 	if (WARN_ON(res_pool->max_count <= 0))
-		goto out;
+		goto out_unlock;
 	if (WARN_ON(res_pool->free_count <= 0 ||
-		goto out;
+		goto out_unlock;
 	 * If the device is currently allocated, its resource is not
@@ -139,7 +134,7 @@ static int __must_check fsl_mc_resource_pool_remove_device(struct fsl_mc_device
 			"Device %s cannot be removed from resource pool\n",
 			dev_name(&mc_dev->dev));
-		goto out;
+		goto out_unlock;
 	list_del(&resource->node);
@@ -150,10 +145,9 @@ static int __must_check fsl_mc_resource_pool_remove_device(struct fsl_mc_device
 	devm_kfree(&mc_bus_dev->dev, resource);
 	mc_dev->resource = NULL;
 	error = 0;
+out_unlock:
 out:
-	if (mutex_locked)
 	return error;
@@ -188,21 +182,19 @@ int __must_check fsl_mc_resource_allocate(struct fsl_mc_bus *mc_bus,
 	BUILD_BUG_ON(ARRAY_SIZE(fsl_mc_pool_type_strings) !=
 		     FSL_MC_NUM_POOL_TYPES);
 	*new_resource = NULL;
-		goto error;
+		goto out;
 	res_pool = &mc_bus->resource_pools[pool_type];
 	if (WARN_ON(res_pool->mc_bus != mc_bus))
-		goto error;
+		goto out;
 	resource = list_first_entry_or_null(&res_pool->free_list,
 					    struct fsl_mc_resource, node);
@@ -212,28 +204,26 @@ int __must_check fsl_mc_resource_allocate(struct fsl_mc_bus *mc_bus,
 			"No more resources of type %s left\n",
 			fsl_mc_pool_type_strings[pool_type]);
-		goto error;
+		goto out_unlock;
 	if (WARN_ON(resource->type != pool_type))
-		goto error;
+		goto out_unlock;
 	if (WARN_ON(resource->parent_pool != res_pool))
-		goto error;
+		goto out_unlock;
-		goto error;
+		goto out_unlock;
 	INIT_LIST_HEAD(&resource->node);
 	res_pool->free_count--;
+	error = 0;
+out_unlock:
 	*new_resource = resource;
-	return 0;
-error:
-	if (mutex_locked)
+out:
 	return error;
 EXPORT_SYMBOL_GPL(fsl_mc_resource_allocate);
@@ -241,26 +231,23 @@ EXPORT_SYMBOL_GPL(fsl_mc_resource_allocate);
 void fsl_mc_resource_free(struct fsl_mc_resource *resource)
 	res_pool = resource->parent_pool;
 	if (WARN_ON(resource->type != res_pool->type))
-		goto out;
+		return;
 		    res_pool->free_count >= res_pool->max_count))
-		goto out;
+		goto out_unlock;
 	if (WARN_ON(!list_empty(&resource->node)))
-		goto out;
+		goto out_unlock;
 	list_add_tail(&resource->node, &res_pool->free_list);
-out:
-	if (mutex_locked)
+out_unlock:
 EXPORT_SYMBOL_GPL(fsl_mc_resource_free);
BtrLinux
Privacy Overview
