staging: fsl-mc: bus: Eliminate double function call
Author: Bhaktipriya Shridhar <bhaktipriya96@gmail.com>
A call to irq_find_matching_host was already made and the result
has been stored in mc_msi_domain. mc_msi_domain is again reassigned
using the same function call which is redundant.
irq_find_matching_host returns/locates a domain for a given fwnode.
The domain is identified using device node and bus_token(if several
domains have same device node but different purposes they can be
distinguished using bus-specific token).
http://www.bricktou.com/include/linux/irqdomain_irq_find_matching_host_en.html
Also, of_property_read_bool finds and reads a boolean from a property
device node from which the property value is to be read. It doesn't
alter the device node.
http://lists.infradead.org/pipermail/linux-arm-kernel/2012-February/083698.html
Since, both  the function calls have the same device node and bus_token,
the return values shall be the same. Hence, the second call has been
removed.
This was done using Coccinelle:
@r@
idexpression *x;
identifier f;
position p1,p2;
x@p1 = f(...)
... when != x
x@p2 = f(...)
@script:python@
p1 << r.p1;
p2 << r.p2;
if (p1[0].line == p2[0].line):
  cocci.include_match(False)
idexpression *x;
identifier f;
position r.p1,r.p2;
*x@p1 = f(...)
*x@p2 = f(...)
Signed-off-by: Bhaktipriya Shridhar
 drivers/staging/fsl-mc/bus/irq-gic-v3-its-fsl-mc-msi.c | 2 --
 1 file changed, 2 deletions(-)
diff --git a/drivers/staging/fsl-mc/bus/irq-gic-v3-its-fsl-mc-msi.c b/drivers/staging/fsl-mc/bus/irq-gic-v3-its-fsl-mc-msi.c
index 4e8e822..720e2b0 100644
--- a/drivers/staging/fsl-mc/bus/irq-gic-v3-its-fsl-mc-msi.c
+++ b/drivers/staging/fsl-mc/bus/irq-gic-v3-its-fsl-mc-msi.c
@@ -118,8 +118,6 @@ void its_fsl_mc_msi_cleanup(void)
 		if (!of_property_read_bool(np, "msi-controller"))
 			continue;
-		mc_msi_domain = irq_find_matching_host(np,
-						       DOMAIN_BUS_FSL_MC_MSI);
 		if (mc_msi_domain &&
 		    mc_msi_domain->host_data == &its_fsl_mc_msi_domain_info)
 			irq_domain_remove(mc_msi_domain);
BtrLinux
Privacy Overview
