Staging: fsl-mc: bus: Drop owner assignment from platform_driver
Author: Bhumika Goyal <bhumirks@gmail.com>
For platform_driver, we don't need to set .owner field as is set by
platform driver core. The semantic patch used here first checks whether
platform_driver struct was actually used in a call to set the .owner
field.
The coccinelle script that generated the patch can be found here:
http://www.spinics.net/lists/kernel/msg2029903.html
Signed-off-by: Bhumika Goyal
 drivers/staging/fsl-mc/bus/mc-bus.c | 1 -
 1 file changed, 1 deletion(-)
diff --git a/drivers/staging/fsl-mc/bus/mc-bus.c b/drivers/staging/fsl-mc/bus/mc-bus.c
index 9317561..c42bfac 100644
--- a/drivers/staging/fsl-mc/bus/mc-bus.c
+++ b/drivers/staging/fsl-mc/bus/mc-bus.c
@@ -795,7 +795,6 @@ MODULE_DEVICE_TABLE(of, fsl_mc_bus_match_table);
 static struct platform_driver fsl_mc_bus_driver = {
 	.driver = {
 		   .name = "fsl_mc_bus",
-		   .owner = THIS_MODULE,
 		   .pm = NULL,
 		   .of_match_table = fsl_mc_bus_match_table,
