staging: fbtft: fb_s6d02a1.c: remove extra parentheses around function arguments
Author: Aya Mahfouz <mahfouz.saif.elyazal@gmail.com>
Removes extra parentheses around function arguments. Issue
detected and resolved using the following coccinelle script:
expression e;
identifier f;
f(...,
e
Signed-off-by: Aya Mahfouz
drivers/staging/fbtft/fb_s6d02a1.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/staging/fbtft/fb_s6d02a1.c b/drivers/staging/fbtft/fb_s6d02a1.c
index e412a42..c87aa25 100644
--- a/drivers/staging/fbtft/fb_s6d02a1.c
+++ b/drivers/staging/fbtft/fb_s6d02a1.c
@@ -136,7 +136,7 @@ static int set_var(struct fbtft_par *par)
write_reg(par, 0x36, MY | MV | (par->bgr << 3));
break;
case 180:
- write_reg(par, 0x36, (par->bgr << 3));
+ write_reg(par, 0x36, par->bgr << 3);
break;
case 90:
write_reg(par, 0x36, MX | MV | (par->bgr << 3)); |
break;
case 180:
break;
case 90:
