staging: fbtft: fb_hx8340bn.c: remove extra parentheses around function arguments
Author: Aya Mahfouz <mahfouz.saif.elyazal@gmail.com>
Removes extra parentheses around function arguments. Issue
detected and resolved using the following coccinelle script:
expression e;
identifier f;
f(...,
e
Signed-off-by: Aya Mahfouz
drivers/staging/fbtft/fb_hx8340bn.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/staging/fbtft/fb_hx8340bn.c b/drivers/staging/fbtft/fb_hx8340bn.c
index 26a987a..072b755 100644
--- a/drivers/staging/fbtft/fb_hx8340bn.c
+++ b/drivers/staging/fbtft/fb_hx8340bn.c
@@ -129,7 +129,7 @@ static int set_var(struct fbtft_par *par)
#define MV (1 << 5)
switch (par->info->var.rotate) {
case 0:
- write_reg(par, 0x36, (par->bgr << 3));
+ write_reg(par, 0x36, par->bgr << 3);
break;
case 270:
write_reg(par, 0x36, MX | MV | (par->bgr << 3)); |
#define MV (1 << 5)
case 0:
break;
case 270:
