staging: et131x: Remove useless return variables
Author: Peter Senna Tschudin <peter.senna@gmail.com>
This patch remove variables that are initialized with a constant,
are never updated, and are only used as parameter of return.
Return the constant instead of using a variable.
Verified by compilation only.
The coccinelle script that find and fixes this issue is:
type T;
constant C;
identifier ret;
- T ret = C;
... when != ret
- return ret;
+ return C;
Signed-off-by: Peter Senna Tschudin
Acked-by: Mark Einon
 drivers/staging/et131x/et131x.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/staging/et131x/et131x.c b/drivers/staging/et131x/et131x.c
index d329cf3..1ac7184 100644
--- a/drivers/staging/et131x/et131x.c
+++ b/drivers/staging/et131x/et131x.c
@@ -4237,7 +4237,6 @@ static int et131x_ioctl(struct net_device *netdev, struct ifreq *reqbuf,
 static int et131x_set_packet_filter(struct et131x_adapter *adapter)
 	int filter = adapter->packet_filter;
-	int status = 0;
 	u32 ctrl;
 	u32 pf_ctrl;
@@ -4288,7 +4287,7 @@ static int et131x_set_packet_filter(struct et131x_adapter *adapter)
 		writel(pf_ctrl, &adapter->regs->rxmac.pf_ctrl);
 		writel(ctrl, &adapter->regs->rxmac.ctrl);
-	return status;
+	return 0;
 /* et131x_multicast - The handler to configure multicasting on the interface */
BtrLinux
Privacy Overview
