staging: emxx_udc: rewrite the right hand side of an assignment
Author: Aya Mahfouz <mahfouz.saif.elyazal@gmail.com>
This patch rewrites the right hand side of an assignment for
expressions of the form:
a = (a  b);
to be:
a = b;
where  = << | >>.
This issue was detected and resolved using the following
coccinelle script:
identifier i;
expression e;
-i = (i >> e);
+i >>= e;
identifier i;
expression e;
-i = (i << e);
+i <<= e;
Signed-off-by: Aya Mahfouz
 drivers/staging/emxx_udc/emxx_udc.c | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/staging/emxx_udc/emxx_udc.c b/drivers/staging/emxx_udc/emxx_udc.c
index 6c1de27..ee8f69f 100644
--- a/drivers/staging/emxx_udc/emxx_udc.c
+++ b/drivers/staging/emxx_udc/emxx_udc.c
@@ -1454,7 +1454,7 @@ static int _nbu2ss_set_feature_device(
 		break;
 	case USB_DEVICE_TEST_MODE:
-		wIndex = wIndex >> 8;
+		wIndex >>= 8;
 		if (wIndex <= MAX_TEST_MODE_NUM)
 			result = 0;
 		break;
@@ -1671,7 +1671,7 @@ static int std_req_set_address(struct nbu2ss_udc *udc)
 	if (wValue != (wValue & 0x007F))
 		return -EINVAL;
-	wValue = wValue << USB_ADRS_SHIFT;
+	wValue <<= USB_ADRS_SHIFT;
 	_nbu2ss_writel(&udc->p_regs->USB_ADDRESS, wValue);
 	_nbu2ss_create_ep0_packet(udc, udc->ep0_buf, 0);
BtrLinux
Privacy Overview
