staging: emxx_udc: Do not assign bool to 0/1
Author: Roberta Dobrescu <roberta.dobrescu@gmail.com>
This fixes the following coccinelle warning:
WARNING: Assignment of bool to 0/1
Signed-off-by: Roberta Dobrescu
Acked-by: Daniel Baluta
drivers/staging/emxx_udc/emxx_udc.c | 12 ++++++------
1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/drivers/staging/emxx_udc/emxx_udc.c b/drivers/staging/emxx_udc/emxx_udc.c
index 16265d4..6212efb 100644
--- a/drivers/staging/emxx_udc/emxx_udc.c
+++ b/drivers/staging/emxx_udc/emxx_udc.c
@@ -705,7 +705,7 @@ static int _nbu2ss_ep0_in_transfer(
if (req->req.actual == req->req.length) {
if ((req->req.actual % EP0_PACKETSIZE) == 0) {
if (req->zero) {
- req->zero = 0;
+ req->zero = false;
EP0_send_NULL(udc, FALSE);
return 1;
@@ -795,7 +795,7 @@ static int _nbu2ss_ep0_out_transfer(
if (req->zero) {
- req->zero = 0;
EP0_receive_NULL(udc, FALSE);
return 1;
@@ -1019,7 +1019,7 @@ static int _nbu2ss_epn_out_transfer(
if (result == 0) {
if ((req->req.actual % ep->ep.maxpacket) == 0) {
if (req->zero) {
- req->zero = 0;
return 1;
@@ -1246,12 +1246,12 @@ static int _nbu2ss_start_transfer(
req->div_len = 0;
if (req->req.length == 0)
- req->zero = 0;
else {
if ((req->req.length % ep->ep.maxpacket) == 0)
req->zero = req->req.zero;
else
- req->zero = 0;
if (ep->epnum == 0) {
@@ -2017,7 +2017,7 @@ static inline void _nbu2ss_epn_in_int(
if ((status & EPn_IN_FULL) == 0) {
/* 0 Length Packet */
- req->zero = 0;
_nbu2ss_zero_len_pkt(udc, ep->epnum);
return; |
if (req->zero) {
- req->zero = 0;
return 1;
if (req->zero) {
- req->zero = 0;
return 1;
if (result == 0) {
if (req->zero) {
- req->zero = 0;
return 1;
req->div_len = 0;
- req->zero = 0;
else {
else
- req->zero = 0;
- req->zero = 0;
return;
