staging: dwc2: use devm_ioremap_resource()
Author: Laurent Navet <laurent.navet@gmail.com>
Replace a call to deprecated devm_request_and_ioremap by devm_ioremap_resource.
Found with coccicheck and this semantic patch:
 scripts/coccinelle/api/devm_request_and_ioremap.cocci.
Signed-off-by: Laurent Navet
Reviewed-by: Matthijs Kooijman
Acked-by: Paul Zimmerman
 drivers/staging/dwc2/pci.c | 6 +++---
 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/staging/dwc2/pci.c b/drivers/staging/dwc2/pci.c
index 8d16530..0fcb9a5 100644
--- a/drivers/staging/dwc2/pci.c
+++ b/drivers/staging/dwc2/pci.c
@@ -130,9 +130,9 @@ static int dwc2_driver_probe(struct pci_dev *dev,
 	pci_set_power_state(dev, PCI_D0);
 	hsotg->dev = &dev->dev;
-	hsotg->regs = devm_request_and_ioremap(&dev->dev, &dev->resource[0]);
-	if (!hsotg->regs)
-		return -ENOMEM;
+	hsotg->regs = devm_ioremap_resource(&dev->dev, &dev->resource[0]);
+	if (IS_ERR(hsotg->regs))
+		return PTR_ERR(hsotg->regs);
 	dev_dbg(&dev->dev, "mapped PA %08lx to VA %p\n",
 		(unsigned long)pci_resource_start(dev, 0), hsotg->regs);
