Staging: dst: correct error-handling code
dst_state_alloc returns an ERR_PTR value in an error case instead of NULL.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
@match exists@
expression x, E;
statement S1, S2;
x = dst_state_alloc(...)
... when != x = E
* if (x == NULL || ...) S1 else S2
* if (x == NULL && ...) S1 else S2
Signed-off-by: Julia Lawall
drivers/staging/dst/export.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/staging/dst/export.c b/drivers/staging/dst/export.c
index 80ae4eb..4fbd848 100644
--- a/drivers/staging/dst/export.c
+++ b/drivers/staging/dst/export.c
@@ -159,7 +159,7 @@ static struct dst_state *dst_accept_client(struct dst_state *st)
goto err_out_exit;
new = dst_state_alloc(st->node);
- if (!new) {
+ if (IS_ERR(new)) {
err = -ENOMEM;
goto err_out_release;
goto err_out_exit;
- if (!new) {
err = -ENOMEM;
