staging: Drop unnecessary null test
list_for_each_entry binds its first argument to a non-null value, and thus
any null test on the value of that argument is superfluous.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
iterator I;
expression x;
statement S;
I(x,...) { <...
- if (x != NULL || ...)
  S
Signed-off-by: Julia Lawall
 drivers/staging/pohmelfs/config.c    | 34 ++++++++++++++++------------------
 drivers/staging/tm6000/tm6000-core.c |  6 ++----
 2 files changed, 18 insertions(+), 22 deletions(-)
diff --git a/drivers/staging/pohmelfs/config.c b/drivers/staging/pohmelfs/config.c
index 8c8d1c2..89279ba 100644
--- a/drivers/staging/pohmelfs/config.c
+++ b/drivers/staging/pohmelfs/config.c
@@ -301,10 +301,8 @@ static int pohmelfs_cn_dump(struct cn_msg *msg)
 	mutex_lock(&pohmelfs_config_lock);
-	list_for_each_entry(g, &pohmelfs_config_list, group_entry) {
-		if (g)
-			total_msg += g->num_entry;
+	list_for_each_entry(g, &pohmelfs_config_list, group_entry)
+		total_msg += g->num_entry;
 	if (total_msg == 0) {
 		if (pohmelfs_send_reply(err, 0, POHMELFS_NOINFO_ACK, msg, NULL))
 			err = -ENOMEM;
@@ -312,15 +310,16 @@ static int pohmelfs_cn_dump(struct cn_msg *msg)
-		if (g) {
-			list_for_each_entry_safe(c, tmp, &g->config_list, config_entry) {
-				struct pohmelfs_ctl *sc = &c->state.ctl;
-				if (pohmelfs_send_reply(err, total_msg - i, POHMELFS_CTLINFO_ACK, msg, sc)) {
-					err = -ENOMEM;
-					goto out_unlock;
-				i += 1;
+		list_for_each_entry_safe(c, tmp, &g->config_list,
+					 config_entry) {
+			struct pohmelfs_ctl *sc = &c->state.ctl;
+			if (pohmelfs_send_reply(err, total_msg - i,
+						POHMELFS_CTLINFO_ACK, msg,
+						sc)) {
+				err = -ENOMEM;
+				goto out_unlock;
+			i += 1;
@@ -354,12 +353,11 @@ static int pohmelfs_cn_flush(struct cn_msg *msg)
 	} else {
-			if (g) {
-					list_del(&c->config_entry);
-					g->num_entry--;
-					kfree(c);
+						 config_entry) {
+				list_del(&c->config_entry);
+				g->num_entry--;
+				kfree(c);
diff --git a/drivers/staging/tm6000/tm6000-core.c b/drivers/staging/tm6000/tm6000-core.c
index cded411..80f2bf0 100644
--- a/drivers/staging/tm6000/tm6000-core.c
+++ b/drivers/staging/tm6000/tm6000-core.c
@@ -702,10 +702,8 @@ void tm6000_unregister_extension(struct tm6000_ops *ops)
 	struct tm6000_core *dev = NULL;
 	mutex_lock(&tm6000_devlist_mutex);
-	list_for_each_entry(dev, &tm6000_devlist, devlist) {
-		if (dev)
-			ops->fini(dev);
+	list_for_each_entry(dev, &tm6000_devlist, devlist)
+		ops->fini(dev);
 	mutex_lock(&tm6000_extension_devlist_lock);
 	printk(KERN_INFO "tm6000: Remove (%s) extension\n", ops->name);
BtrLinux
Privacy Overview
