Staging: drivers: Bool initializations should use true/false
Author: Cristina Opriceana <cristina.opriceana@gmail.com>
This patch replaces bool initializations of 1/0 with true/false in order
to increase readability and respect the standards. Warning found by
coccinelle.
Signed-off-by: Cristina Opriceana
 drivers/staging/ft1000/ft1000-usb/ft1000_debug.c       | 4 ++--
 drivers/staging/lustre/lustre/llite/llite_mmap.c       | 2 +-
 drivers/staging/rtl8192u/ieee80211/dot11d.c            | 2 +-
 drivers/staging/rtl8192u/ieee80211/ieee80211_rx.c      | 2 +-
 drivers/staging/rtl8192u/ieee80211/ieee80211_softmac.c | 4 ++--
 drivers/staging/rtl8192u/r8192U_core.c                 | 2 +-
 drivers/staging/rtl8192u/r8192U_dm.c                   | 4 ++--
 drivers/staging/vt6655/rxtx.c                          | 4 ++--
 8 files changed, 12 insertions(+), 12 deletions(-)
diff --git a/drivers/staging/ft1000/ft1000-usb/ft1000_debug.c b/drivers/staging/ft1000/ft1000-usb/ft1000_debug.c
index da34257..0f776d0 100644
--- a/drivers/staging/ft1000/ft1000-usb/ft1000_debug.c
+++ b/drivers/staging/ft1000/ft1000-usb/ft1000_debug.c
@@ -544,7 +544,7 @@ static long ft1000_ioctl(struct file *file, unsigned int command,
 		if (ft1000dev->fProvComplete == 0)
 			return -EACCES;
-		ft1000dev->fAppMsgPend = 1;
+		ft1000dev->fAppMsgPend = true;
 		if (info->CardReady) {
@@ -719,7 +719,7 @@ static long ft1000_ioctl(struct file *file, unsigned int command,
 		result = -ENOTTY;
 		break;
-	ft1000dev->fAppMsgPend = 0;
+	ft1000dev->fAppMsgPend = false;
 	return result;
diff --git a/drivers/staging/lustre/lustre/llite/llite_mmap.c b/drivers/staging/lustre/lustre/llite/llite_mmap.c
index ab07959..a90214b 100644
--- a/drivers/staging/lustre/lustre/llite/llite_mmap.c
+++ b/drivers/staging/lustre/lustre/llite/llite_mmap.c
@@ -312,7 +312,7 @@ static int ll_fault0(struct vm_area_struct *vma, struct vm_fault *vmf)
 		vio->u.fault.ft_vmpage    = NULL;
 		vio->u.fault.fault.ft_vmf = vmf;
 		vio->u.fault.fault.ft_flags = 0;
-		vio->u.fault.fault.ft_flags_valid = 0;
+		vio->u.fault.fault.ft_flags_valid = false;
 		result = cl_io_loop(env, io);
diff --git a/drivers/staging/rtl8192u/ieee80211/dot11d.c b/drivers/staging/rtl8192u/ieee80211/dot11d.c
index 90ace79..82d6038 100644
--- a/drivers/staging/rtl8192u/ieee80211/dot11d.c
+++ b/drivers/staging/rtl8192u/ieee80211/dot11d.c
@@ -6,7 +6,7 @@ void Dot11d_Init(struct ieee80211_device *ieee)
 	PRT_DOT11D_INFO pDot11dInfo = GET_DOT11D_INFO(ieee);
-	pDot11dInfo->bEnabled = 0;
+	pDot11dInfo->bEnabled = false;
 	pDot11dInfo->State = DOT11D_STATE_NONE;
 	pDot11dInfo->CountryIeLen = 0;
diff --git a/drivers/staging/rtl8192u/ieee80211/ieee80211_rx.c b/drivers/staging/rtl8192u/ieee80211/ieee80211_rx.c
index 286b71d..d2c2fb8 100644
--- a/drivers/staging/rtl8192u/ieee80211/ieee80211_rx.c
+++ b/drivers/staging/rtl8192u/ieee80211/ieee80211_rx.c
@@ -943,7 +943,7 @@ int ieee80211_rx(struct ieee80211_device *ieee, struct sk_buff *skb,
 		if(net_ratelimit())
 		printk("find HTCControl\n");
 		hdrlen += 4;
-		rx_stats->bContainHTC = 1;
+		rx_stats->bContainHTC = true;
 	//IEEE80211_DEBUG_DATA(IEEE80211_DL_DATA, skb->data, skb->len);
diff --git a/drivers/staging/rtl8192u/ieee80211/ieee80211_softmac.c b/drivers/staging/rtl8192u/ieee80211/ieee80211_softmac.c
index 3527edc..878086a 100644
--- a/drivers/staging/rtl8192u/ieee80211/ieee80211_softmac.c
+++ b/drivers/staging/rtl8192u/ieee80211/ieee80211_softmac.c
@@ -1371,7 +1371,7 @@ static void ieee80211_associate_complete_wq(struct work_struct *work)
 	else if(ieee->is_silent_reset == 1)
 		printk("==================>silent reset associate\n");
-		ieee->is_silent_reset = 0;
+		ieee->is_silent_reset = false;
 	if (ieee->data_hard_resume)
@@ -2719,7 +2719,7 @@ void ieee80211_softmac_init(struct ieee80211_device *ieee)
 	ieee->sta_edca_param[2] = 0x005E4342;
 	ieee->sta_edca_param[3] = 0x002F3262;
 	ieee->aggregation = true;
-	ieee->enable_rx_imm_BA = 1;
+	ieee->enable_rx_imm_BA = true;
 	ieee->tx_pending.txb = NULL;
 	setup_timer(&ieee->associate_timer, ieee80211_associate_abort_cb,
diff --git a/drivers/staging/rtl8192u/r8192U_core.c b/drivers/staging/rtl8192u/r8192U_core.c
index bab7751..0d64d2d 100644
--- a/drivers/staging/rtl8192u/r8192U_core.c
+++ b/drivers/staging/rtl8192u/r8192U_core.c
@@ -2143,7 +2143,7 @@ static void rtl8192_init_priv_variable(struct net_device *dev)
 	//for silent reset
 	priv->IrpPendingCount = 1;
 	priv->ResetProgress = RESET_TYPE_NORESET;
-	priv->bForcedSilentReset = 0;
+	priv->bForcedSilentReset = false;
 	priv->bDisableNormalResetCheck = false;
 	priv->force_reset = false;
diff --git a/drivers/staging/rtl8192u/r8192U_dm.c b/drivers/staging/rtl8192u/r8192U_dm.c
index 5a01b7d..16cafcd 100644
--- a/drivers/staging/rtl8192u/r8192U_dm.c
+++ b/drivers/staging/rtl8192u/r8192U_dm.c
@@ -2419,9 +2419,9 @@ void dm_rf_pathcheck_workitemcallback(struct work_struct *work)
 	/* Check Bit 0-3, it means if RF A-D is enabled. */
 	for (i = 0; i < RF90_PATH_MAX; i++) {
 		if (rfpath & (0x01<<i))
-			priv->brfpath_rxenable[i] = 1;
+			priv->brfpath_rxenable[i] = true;
 		else
-			priv->brfpath_rxenable[i] = 0;
+			priv->brfpath_rxenable[i] = false;
 	if (!DM_RxPathSelTable.Enable)
 		return;
diff --git a/drivers/staging/vt6655/rxtx.c b/drivers/staging/vt6655/rxtx.c
index ac8c8b5..2b4f005 100644
--- a/drivers/staging/vt6655/rxtx.c
+++ b/drivers/staging/vt6655/rxtx.c
@@ -248,11 +248,11 @@ s_uGetDataDuration(
 	unsigned char byFBOption
-	bool bLastFrag = 0;
+	bool bLastFrag = false;
 	unsigned int uAckTime = 0, uNextPktTime = 0;
 	if (uFragIdx == (uMACfragNum-1))
-		bLastFrag = 1;
+		bLastFrag = true;
 	switch (byDurType) {
 	case DATADUR_B:    //DATADUR_B
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
