Staging: dream: camera: Use memdup_user
Use memdup_user when user data is immediately copied into the
allocated region.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
expression from,to,size,flag;
position p;
identifier l1,l2;
-  to = \(kmalloc@p\|kzalloc@p\)(size,flag);
+  to = memdup_user(from,size);
   if (
-      to==NULL
+      IS_ERR(to)
   <+... when != goto l1;
-  -ENOMEM
+  PTR_ERR(to)
-  if (copy_from_user(to, from, size) != 0) {
-    <+... when != goto l2;
-    -EFAULT
Signed-off-by: Julia Lawall
 drivers/staging/dream/camera/msm_vfe8x.c | 45 +++++++++-----------------------
 1 file changed, 12 insertions(+), 33 deletions(-)
diff --git a/drivers/staging/dream/camera/msm_vfe8x.c b/drivers/staging/dream/camera/msm_vfe8x.c
index e61fdba..d87d56f 100644
--- a/drivers/staging/dream/camera/msm_vfe8x.c
+++ b/drivers/staging/dream/camera/msm_vfe8x.c
@@ -644,17 +644,10 @@ static int vfe_config(struct msm_vfe_cfg_cmd *cmd, void *data)
 		if (!axid)
 			return -EFAULT;
-		axio =
-			kmalloc(sizeof(struct vfe_cmd_axi_output_config),
-				GFP_ATOMIC);
-		if (!axio)
-			return -ENOMEM;
-		if (copy_from_user(axio, (void __user *)(vfecmd.value),
-			sizeof(struct vfe_cmd_axi_output_config))) {
-			kfree(axio);
-			return -EFAULT;
+		axio = memdup_user((void __user *)(vfecmd.value),
+				   sizeof(struct vfe_cmd_axi_output_config));
+		if (IS_ERR(axio))
+			return PTR_ERR(axio);
 		vfe_config_axi(OUTPUT_1, axid, axio);
 		vfe_axi_output_config(axio);
@@ -669,17 +662,10 @@ static int vfe_config(struct msm_vfe_cfg_cmd *cmd, void *data)
 		if (!axid)
 			return -EFAULT;
-		axio =
-				GFP_ATOMIC);
-		if (!axio)
-			return -ENOMEM;
-			kfree(axio);
-			return -EFAULT;
+		if (IS_ERR(axio))
 		vfe_config_axi(OUTPUT_2, axid, axio);
@@ -694,17 +680,10 @@ static int vfe_config(struct msm_vfe_cfg_cmd *cmd, void *data)
 		if (!axid)
 			return -EFAULT;
-		axio =
-				GFP_ATOMIC);
-		if (!axio)
-			return -ENOMEM;
-			kfree(axio);
-			return -EFAULT;
+		if (IS_ERR(axio))
 		vfe_config_axi(OUTPUT_1_AND_2,
 			axid, axio);
BtrLinux
Privacy Overview
