Staging: dgnc: Merge lines and remove unused variable for immediate return
Author: Vaishali Thakkar <vthakkar1994@gmail.com>
This patch merges two lines in a single line if immediate
return is found. It also removes unnecessory variable rc
as it is no longer needed.
This is done using Coccinelle. Semantic patch used for this
is as follows:
type T;
identifier i;
identifier f;
constant C;
- T i;
...when != i
when strict
return -C;
- i =
+ return
f(...);
- return i;
Signed-off-by: Vaishali Thakkar
Reviewed-by: Julia Lawall
drivers/staging/dgnc/dgnc_tty.c | 5 +----
1 file changed, 1 insertion(+), 4 deletions(-)
diff --git a/drivers/staging/dgnc/dgnc_tty.c b/drivers/staging/dgnc/dgnc_tty.c
index 0e903dc..a4e6c9e 100644
--- a/drivers/staging/dgnc/dgnc_tty.c
+++ b/drivers/staging/dgnc/dgnc_tty.c
@@ -2286,7 +2286,6 @@ static inline int dgnc_get_mstat(struct channel_t *ch)
static int dgnc_get_modem_info(struct channel_t *ch, unsigned int __user *value)
int result;
- int rc;
if (!ch || ch->magic != DGNC_CHANNEL_MAGIC)
return -ENXIO;
@@ -2296,9 +2295,7 @@ static int dgnc_get_modem_info(struct channel_t *ch, unsigned int __user *value
if (result < 0)
return -ENXIO;
- rc = put_user(result, value);
- return rc;
+ return put_user(result, value);
int result;
- int rc;
return -ENXIO;
if (result < 0)
return -ENXIO;
- return rc;
