drivers/staging/dgnc/dgnc_tty.c | 293 ++++++++++++++++++++--------------------
1 file changed, 147 insertions(+), 146 deletions(-)
diff --git a/drivers/staging/dgnc/dgnc_tty.c b/drivers/staging/dgnc/dgnc_tty.c
index a4e6c9e..3892da2 100644
--- a/drivers/staging/dgnc/dgnc_tty.c
+++ b/drivers/staging/dgnc/dgnc_tty.c
@@ -342,7 +342,7 @@ int dgnc_tty_init(struct dgnc_board *brd)
if (!brd->channels[i])
continue;
- DGNC_SPINLOCK_INIT(ch->ch_lock);
+ spin_lock_init(&ch->ch_lock);
/* Store all our magic numbers */
ch->magic = DGNC_CHANNEL_MAGIC;
@@ -631,7 +631,7 @@ void dgnc_input(struct channel_t *ch)
ushort head;
ushort tail;
int data_len;
- ulong lock_flags;
+ unsigned long flags;
int flip_len;
int len = 0;
int n = 0;
@@ -647,7 +647,7 @@ void dgnc_input(struct channel_t *ch)
if (!bd || bd->magic != DGNC_BOARD_MAGIC)
return;
- DGNC_LOCK(ch->ch_lock, lock_flags);
+ spin_lock_irqsave(&ch->ch_lock, flags);
* Figure the number of characters in the buffer.
@@ -659,7 +659,7 @@ void dgnc_input(struct channel_t *ch)
data_len = (head - tail) & rmask;
if (data_len == 0) {
- DGNC_UNLOCK(ch->ch_lock, lock_flags);
+ spin_unlock_irqrestore(&ch->ch_lock, flags);
return;
@@ -675,7 +675,7 @@ void dgnc_input(struct channel_t *ch)
/* Force queue flow control to be released, if needed */
dgnc_check_queue_flow_control(ch);
return;
@@ -683,7 +683,7 @@ void dgnc_input(struct channel_t *ch)
* If we are throttled, simply don't read any data.
if (ch->ch_flags & CH_FORCED_STOPI) {
return;
@@ -724,7 +724,7 @@ void dgnc_input(struct channel_t *ch)
if (len <= 0) {
if (ld)
tty_ldisc_deref(ld);
return;
@@ -791,7 +791,7 @@ void dgnc_input(struct channel_t *ch)
ch->ch_r_tail = tail & rmask;
ch->ch_e_tail = tail & rmask;
/* Tell the tty layer its okay to "eat" the data now */
tty_flip_buffer_push(tp->port);
@@ -1052,12 +1052,12 @@ void dgnc_check_queue_flow_control(struct channel_t *ch)
void dgnc_wakeup_writes(struct channel_t *ch)
int qlen = 0;
- ulong lock_flags;
if (!ch || ch->magic != DGNC_CHANNEL_MAGIC)
return;
* If channel now has space, wake up anyone waiting on the condition.
@@ -1067,16 +1067,16 @@ void dgnc_wakeup_writes(struct channel_t *ch)
qlen += WQUEUESIZE;
if (qlen >= (WQUEUESIZE - 256)) {
return;
if (ch->ch_tun.un_flags & UN_ISOPEN) {
if ((ch->ch_tun.un_tty->flags & (1 << TTY_DO_WRITE_WAKEUP)) &&
ch->ch_tun.un_tty->ldisc->ops->write_wakeup) {
(ch->ch_tun.un_tty->ldisc->ops->write_wakeup)(ch->ch_tun.un_tty);
wake_up_interruptible(&ch->ch_tun.un_tty->write_wait);
@@ -1115,9 +1115,9 @@ void dgnc_wakeup_writes(struct channel_t *ch)
if (ch->ch_pun.un_flags & UN_ISOPEN) {
if ((ch->ch_pun.un_tty->flags & (1 << TTY_DO_WRITE_WAKEUP)) &&
ch->ch_pun.un_tty->ldisc->ops->write_wakeup) {
(ch->ch_pun.un_tty->ldisc->ops->write_wakeup)(ch->ch_pun.un_tty);
wake_up_interruptible(&ch->ch_pun.un_tty->write_wait);
@@ -1135,7 +1135,7 @@ void dgnc_wakeup_writes(struct channel_t *ch)
wake_up_interruptible(&ch->ch_pun.un_flags_wait);
@@ -1158,7 +1158,7 @@ static int dgnc_tty_open(struct tty_struct *tty, struct file *file)
uint major = 0;
uint minor = 0;
int rc = 0;
- ulong lock_flags;
rc = 0;
@@ -1183,25 +1183,25 @@ static int dgnc_tty_open(struct tty_struct *tty, struct file *file)
if (rc)
return rc;
- DGNC_LOCK(brd->bd_lock, lock_flags);
+ spin_lock_irqsave(&brd->bd_lock, flags);
/* If opened device is greater than our number of ports, bail. */
if (PORT_NUM(minor) > brd->nasync) {
- DGNC_UNLOCK(brd->bd_lock, lock_flags);
+ spin_unlock_irqrestore(&brd->bd_lock, flags);
return -ENXIO;
ch = brd->channels[PORT_NUM(minor)];
if (!ch) {
return -ENXIO;
/* Drop board lock */
/* Grab channel lock */
/* Figure out our type */
if (!IS_PRINT(minor)) {
@@ -1211,7 +1211,7 @@ static int dgnc_tty_open(struct tty_struct *tty, struct file *file)
un = &brd->channels[PORT_NUM(minor)]->ch_pun;
un->un_type = DGNC_PRINT;
} else {
return -ENXIO;
@@ -1220,7 +1220,7 @@ static int dgnc_tty_open(struct tty_struct *tty, struct file *file)
* where we simply cannot safely keep going, wait until the
* state clears.
rc = wait_event_interruptible(ch->ch_flags_wait, ((ch->ch_flags & CH_OPENING) == 0));
@@ -1242,7 +1242,7 @@ static int dgnc_tty_open(struct tty_struct *tty, struct file *file)
if (rc)
return -EINTR;
/* Store our unit into driver_data, so we always have it available. */
@@ -1267,7 +1267,7 @@ static int dgnc_tty_open(struct tty_struct *tty, struct file *file)
ch->ch_flags |= (CH_OPENING);
/* Drop locks, as malloc with GFP_KERNEL can sleep */
if (!ch->ch_rqueue)
ch->ch_rqueue = kzalloc(RQUEUESIZE, GFP_KERNEL);
@@ -1276,7 +1276,7 @@ static int dgnc_tty_open(struct tty_struct *tty, struct file *file)
if (!ch->ch_wqueue)
ch->ch_wqueue = kzalloc(WQUEUESIZE, GFP_KERNEL);
ch->ch_flags &= ~(CH_OPENING);
wake_up_interruptible(&ch->ch_flags_wait);
@@ -1335,16 +1335,16 @@ static int dgnc_tty_open(struct tty_struct *tty, struct file *file)
* follow protocol for opening port
rc = dgnc_block_til_ready(tty, file, ch);
/* No going back now, increment our unit and channel counters */
ch->ch_open_count++;
un->un_open_count++;
un->un_flags |= (UN_ISOPEN);
return rc;
@@ -1359,7 +1359,7 @@ static int dgnc_block_til_ready(struct tty_struct *tty, struct file *file, struc
int retval = 0;
struct un_t *un = NULL;
- ulong lock_flags;
uint old_flags = 0;
int sleep_on_un_flags = 0;
@@ -1371,7 +1371,7 @@ static int dgnc_block_til_ready(struct tty_struct *tty, struct file *file, struc
if (!un || un->magic != DGNC_UNIT_MAGIC)
return -ENXIO;
ch->ch_wopen++;
@@ -1451,7 +1451,7 @@ static int dgnc_block_til_ready(struct tty_struct *tty, struct file *file, struc
* eventually goes active.
* Wait for something in the flags to change from the current value.
@@ -1467,12 +1467,12 @@ static int dgnc_block_til_ready(struct tty_struct *tty, struct file *file, struc
* We got woken up for some reason.
* Before looping around, grab our channel lock.
ch->ch_wopen--;
if (retval)
return retval;
@@ -1513,7 +1513,7 @@ static void dgnc_tty_close(struct tty_struct *tty, struct file *file)
struct dgnc_board *bd;
struct channel_t *ch;
struct un_t *un;
- ulong lock_flags;
int rc = 0;
if (!tty || tty->magic != TTY_MAGIC)
@@ -1533,7 +1533,7 @@ static void dgnc_tty_close(struct tty_struct *tty, struct file *file)
ts = &tty->termios;
* Determine if this is the last close or not - and if we agree about
@@ -1559,7 +1559,7 @@ static void dgnc_tty_close(struct tty_struct *tty, struct file *file)
ch->ch_open_count--;
if (ch->ch_open_count && un->un_open_count) {
return;
@@ -1586,7 +1586,7 @@ static void dgnc_tty_close(struct tty_struct *tty, struct file *file)
ch->ch_flags &= ~CH_PRON;
/* wait for output to drain */
/* This will also return if we take an interrupt */
@@ -1595,7 +1595,7 @@ static void dgnc_tty_close(struct tty_struct *tty, struct file *file)
dgnc_tty_flush_buffer(tty);
tty_ldisc_flush(tty);
tty->closing = 0;
@@ -1613,9 +1613,10 @@ static void dgnc_tty_close(struct tty_struct *tty, struct file *file)
* have been dropped for modems to see it.
if (ch->ch_close_delay) {
+ flags);
dgnc_ms_sleep(ch->ch_close_delay);
@@ -1640,7 +1641,7 @@ static void dgnc_tty_close(struct tty_struct *tty, struct file *file)
wake_up_interruptible(&un->un_flags_wait);
@@ -1660,7 +1661,7 @@ static int dgnc_tty_chars_in_buffer(struct tty_struct *tty)
ushort ttail;
uint tmask;
uint chars = 0;
- ulong lock_flags = 0;
if (tty == NULL)
return 0;
@@ -1673,13 +1674,13 @@ static int dgnc_tty_chars_in_buffer(struct tty_struct *tty)
return 0;
tmask = WQUEUEMASK;
thead = ch->ch_w_head & tmask;
ttail = ch->ch_w_tail & tmask;
if (ttail == thead) {
chars = 0;
@@ -1763,7 +1764,7 @@ static int dgnc_tty_write_room(struct tty_struct *tty)
ushort tail;
ushort tmask;
int ret = 0;
if (tty == NULL || dgnc_TmpWriteBuf == NULL)
return 0;
@@ -1776,7 +1777,7 @@ static int dgnc_tty_write_room(struct tty_struct *tty)
return 0;
tmask = WQUEUEMASK;
head = (ch->ch_w_head) & tmask;
@@ -1805,7 +1806,7 @@ static int dgnc_tty_write_room(struct tty_struct *tty)
if (ret < 0)
ret = 0;
return ret;
@@ -1841,7 +1842,7 @@ static int dgnc_tty_write(struct tty_struct *tty,
int bufcount = 0, n = 0;
int orig_count = 0;
- ulong lock_flags;
ushort head;
ushort tail;
ushort tmask;
@@ -1869,7 +1870,7 @@ static int dgnc_tty_write(struct tty_struct *tty,
orig_count = count;
/* Get our space available for the channel from the board */
tmask = WQUEUEMASK;
@@ -1896,7 +1897,7 @@ static int dgnc_tty_write(struct tty_struct *tty,
* Bail if no space left.
if (count <= 0) {
return 0;
@@ -1926,7 +1927,7 @@ static int dgnc_tty_write(struct tty_struct *tty,
* If there is nothing left to copy, or I can't handle any more data, leave.
if (count <= 0) {
return 0;
@@ -1934,7 +1935,7 @@ static int dgnc_tty_write(struct tty_struct *tty,
count = min(count, WRITEBUFLEN);
* If data is coming from user space, copy it into a temporary
@@ -1956,7 +1957,7 @@ static int dgnc_tty_write(struct tty_struct *tty,
return -EFAULT;
buf = dgnc_TmpWriteBuf;
@@ -2001,10 +2002,10 @@ static int dgnc_tty_write(struct tty_struct *tty,
if (from_user) {
up(&dgnc_TmpWriteSem);
} else {
if (count) {
@@ -2029,7 +2030,7 @@ static int dgnc_tty_tiocmget(struct tty_struct *tty)
struct un_t *un;
int result = -EIO;
uchar mstat = 0;
- ulong lock_flags;
return result;
@@ -2042,11 +2043,11 @@ static int dgnc_tty_tiocmget(struct tty_struct *tty)
return result;
mstat = (ch->ch_mostat | ch->ch_mistat);
result = 0;
@@ -2080,7 +2081,7 @@ static int dgnc_tty_tiocmset(struct tty_struct *tty,
struct un_t *un;
int ret = -EIO;
- ulong lock_flags;
return ret;
@@ -2097,7 +2098,7 @@ static int dgnc_tty_tiocmset(struct tty_struct *tty,
return ret;
if (set & TIOCM_RTS)
ch->ch_mostat |= UART_MCR_RTS;
@@ -2113,7 +2114,7 @@ static int dgnc_tty_tiocmset(struct tty_struct *tty,
ch->ch_bd->bd_ops->assert_modem_signals(ch);
return 0;
@@ -2130,7 +2131,7 @@ static int dgnc_tty_send_break(struct tty_struct *tty, int msec)
struct un_t *un;
int ret = -EIO;
- ulong lock_flags;
return ret;
@@ -2158,11 +2159,11 @@ static int dgnc_tty_send_break(struct tty_struct *tty, int msec)
break;
ch->ch_bd->bd_ops->send_break(ch, msec);
return 0;
@@ -2212,7 +2213,7 @@ static void dgnc_tty_send_xchar(struct tty_struct *tty, char c)
struct un_t *un;
- ulong lock_flags;
return;
@@ -2231,9 +2232,9 @@ static void dgnc_tty_send_xchar(struct tty_struct *tty, char c)
dev_dbg(tty->dev, "dgnc_tty_send_xchar start\n");
bd->bd_ops->send_immediate_char(ch, c);
dev_dbg(tty->dev, "dgnc_tty_send_xchar finish\n");
return;
@@ -2249,16 +2250,16 @@ static inline int dgnc_get_mstat(struct channel_t *ch)
unsigned char mstat;
int result = -EIO;
- ulong lock_flags;
return -ENXIO;
result = 0;
@@ -2311,7 +2312,7 @@ static int dgnc_set_modem_info(struct tty_struct *tty, unsigned int command, uns
struct un_t *un;
int ret = -ENXIO;
unsigned int arg = 0;
- ulong lock_flags;
return ret;
@@ -2371,11 +2372,11 @@ static int dgnc_set_modem_info(struct tty_struct *tty, unsigned int command, uns
return -EINVAL;
return 0;
@@ -2394,7 +2395,7 @@ static int dgnc_tty_digigeta(struct tty_struct *tty, struct digi_t __user *retin
struct un_t *un;
struct digi_t tmp;
- ulong lock_flags;
if (!retinfo)
return -EFAULT;
@@ -2412,9 +2413,9 @@ static int dgnc_tty_digigeta(struct tty_struct *tty, struct digi_t __user *retin
memset(&tmp, 0, sizeof(tmp));
memcpy(&tmp, &ch->ch_digi, sizeof(tmp));
if (copy_to_user(retinfo, &tmp, sizeof(*retinfo)))
return -EFAULT;
@@ -2437,7 +2438,7 @@ static int dgnc_tty_digiseta(struct tty_struct *tty, struct digi_t __user *new_i
struct un_t *un;
struct digi_t new_digi;
- ulong lock_flags;
return -EFAULT;
@@ -2457,7 +2458,7 @@ static int dgnc_tty_digiseta(struct tty_struct *tty, struct digi_t __user *new_i
if (copy_from_user(&new_digi, new_info, sizeof(new_digi)))
return -EFAULT;
* Handle transistions to and from RTS Toggle.
@@ -2500,7 +2501,7 @@ static int dgnc_tty_digiseta(struct tty_struct *tty, struct digi_t __user *new_i
ch->ch_bd->bd_ops->param(tty);
return 0;
@@ -2514,7 +2515,7 @@ static void dgnc_tty_set_termios(struct tty_struct *tty, struct ktermios *old_te
struct un_t *un;
- unsigned long lock_flags;
return;
@@ -2531,7 +2532,7 @@ static void dgnc_tty_set_termios(struct tty_struct *tty, struct ktermios *old_te
return;
ch->ch_c_cflag = tty->termios.c_cflag;
ch->ch_c_iflag = tty->termios.c_iflag;
@@ -2543,7 +2544,7 @@ static void dgnc_tty_set_termios(struct tty_struct *tty, struct ktermios *old_te
dgnc_carrier(ch);
@@ -2551,7 +2552,7 @@ static void dgnc_tty_throttle(struct tty_struct *tty)
struct un_t *un;
return;
@@ -2564,11 +2565,11 @@ static void dgnc_tty_throttle(struct tty_struct *tty)
return;
ch->ch_flags |= (CH_FORCED_STOPI);
@@ -2576,7 +2577,7 @@ static void dgnc_tty_unthrottle(struct tty_struct *tty)
struct un_t *un;
- ulong lock_flags;
return;
@@ -2589,11 +2590,11 @@ static void dgnc_tty_unthrottle(struct tty_struct *tty)
return;
ch->ch_flags &= ~(CH_FORCED_STOPI);
@@ -2602,7 +2603,7 @@ static void dgnc_tty_start(struct tty_struct *tty)
struct un_t *un;
- ulong lock_flags;
return;
@@ -2619,11 +2620,11 @@ static void dgnc_tty_start(struct tty_struct *tty)
return;
ch->ch_flags &= ~(CH_FORCED_STOP);
@@ -2632,7 +2633,7 @@ static void dgnc_tty_stop(struct tty_struct *tty)
struct un_t *un;
- ulong lock_flags;
return;
@@ -2649,11 +2650,11 @@ static void dgnc_tty_stop(struct tty_struct *tty)
return;
ch->ch_flags |= (CH_FORCED_STOP);
@@ -2675,7 +2676,7 @@ static void dgnc_tty_flush_chars(struct tty_struct *tty)
struct un_t *un;
- ulong lock_flags;
return;
@@ -2692,11 +2693,11 @@ static void dgnc_tty_flush_chars(struct tty_struct *tty)
return;
/* Do something maybe here */
@@ -2710,7 +2711,7 @@ static void dgnc_tty_flush_buffer(struct tty_struct *tty)
struct un_t *un;
- ulong lock_flags;
return;
@@ -2723,7 +2724,7 @@ static void dgnc_tty_flush_buffer(struct tty_struct *tty)
return;
ch->ch_flags &= ~CH_STOP;
@@ -2742,7 +2743,7 @@ static void dgnc_tty_flush_buffer(struct tty_struct *tty)
@@ -2765,7 +2766,7 @@ static int dgnc_tty_ioctl(struct tty_struct *tty, unsigned int cmd,
struct un_t *un;
int rc;
- ulong lock_flags;
void __user *uarg = (void __user *) arg;
@@ -2783,10 +2784,10 @@ static int dgnc_tty_ioctl(struct tty_struct *tty, unsigned int cmd,
return -ENODEV;
if (un->un_open_count <= 0) {
return -EIO;
@@ -2804,7 +2805,7 @@ static int dgnc_tty_ioctl(struct tty_struct *tty, unsigned int cmd,
* in the middle: 0.375 seconds.
rc = tty_check_change(tty);
if (rc)
return rc;
@@ -2813,13 +2814,13 @@ static int dgnc_tty_ioctl(struct tty_struct *tty, unsigned int cmd,
if (rc)
return -EINTR;
if (((cmd == TCSBRK) && (!arg)) || (cmd == TCSBRKP)) {
ch->ch_bd->bd_ops->send_break(ch, 250);
return 0;
@@ -2831,7 +2832,7 @@ static int dgnc_tty_ioctl(struct tty_struct *tty, unsigned int cmd,
if (rc)
return rc;
@@ -2839,17 +2840,17 @@ static int dgnc_tty_ioctl(struct tty_struct *tty, unsigned int cmd,
if (rc)
return -EINTR;
return 0;
case TIOCSBRK:
if (rc)
return rc;
@@ -2857,48 +2858,48 @@ static int dgnc_tty_ioctl(struct tty_struct *tty, unsigned int cmd,
if (rc)
return -EINTR;
return 0;
case TIOCCBRK:
/* Do Nothing */
return 0;
case TIOCGSOFTCAR:
rc = put_user(C_CLOCAL(tty) ? 1 : 0, (unsigned long __user *) arg);
return rc;
case TIOCSSOFTCAR:
rc = get_user(arg, (unsigned long __user *) arg);
if (rc)
return rc;
tty->termios.c_cflag = ((tty->termios.c_cflag & ~CLOCAL) | (arg ? CLOCAL : 0));
return 0;
case TIOCMGET:
return dgnc_get_modem_info(ch, uarg);
case TIOCMBIS:
case TIOCMBIC:
case TIOCMSET:
return dgnc_set_modem_info(tty, cmd, uarg);
@@ -2917,7 +2918,7 @@ static int dgnc_tty_ioctl(struct tty_struct *tty, unsigned int cmd,
if (rc) {
return rc;
@@ -2947,7 +2948,7 @@ static int dgnc_tty_ioctl(struct tty_struct *tty, unsigned int cmd,
/* pretend we didn't recognize this IOCTL */
return -ENOIOCTLCMD;
case TCSETSF:
case TCSETSW:
@@ -2970,7 +2971,7 @@ static int dgnc_tty_ioctl(struct tty_struct *tty, unsigned int cmd,
/* now wait for all the output to drain */
rc = ch->ch_bd->bd_ops->drain(tty, 0);
if (rc)
return -EINTR;
@@ -2980,7 +2981,7 @@ static int dgnc_tty_ioctl(struct tty_struct *tty, unsigned int cmd,
case TCSETAW:
if (rc)
return -EINTR;
@@ -2989,13 +2990,13 @@ static int dgnc_tty_ioctl(struct tty_struct *tty, unsigned int cmd,
case TCXONC:
/* Make the ld do it */
case DIGI_GETA:
/* get information for ditty */
return dgnc_tty_digigeta(tty, uarg);
case DIGI_SETAW:
@@ -3004,31 +3005,31 @@ static int dgnc_tty_ioctl(struct tty_struct *tty, unsigned int cmd,
/* set information for ditty */
if (cmd == (DIGI_SETAW)) {
if (rc)
return -EINTR;
} else {
/* fall thru */
case DIGI_SETA:
return dgnc_tty_digiseta(tty, uarg);
case DIGI_LOOPBACK:
uint loopback = 0;
/* Let go of locks when accessing user space, could sleep */
rc = get_user(loopback, (unsigned int __user *) arg);
if (rc)
return rc;
/* Enable/disable internal loopback for this port */
if (loopback)
@@ -3037,12 +3038,12 @@ static int dgnc_tty_ioctl(struct tty_struct *tty, unsigned int cmd,
ch->ch_flags &= ~(CH_LOOPBACK);
return 0;
case DIGI_GETCUSTOMBAUD:
rc = put_user(ch->ch_custom_speed, (unsigned int __user *) arg);
return rc;
@@ -3050,14 +3051,14 @@ static int dgnc_tty_ioctl(struct tty_struct *tty, unsigned int cmd,
int new_rate;
rc = get_user(new_rate, (int __user *) arg);
if (rc)
return rc;
dgnc_set_custom_speed(ch, new_rate);
return 0;
@@ -3071,13 +3072,13 @@ static int dgnc_tty_ioctl(struct tty_struct *tty, unsigned int cmd,
case DIGI_REALPORT_SENDIMMEDIATE:
unsigned char c;
rc = get_user(c, (unsigned char __user *) arg);
if (rc)
return rc;
ch->ch_bd->bd_ops->send_immediate_char(ch, c);
return 0;
@@ -3099,7 +3100,7 @@ static int dgnc_tty_ioctl(struct tty_struct *tty, unsigned int cmd,
buf.rbytes = ch->ch_rxcount;
buf.tbytes = ch->ch_txcount;
if (copy_to_user(uarg, &buf, sizeof(buf)))
return -EFAULT;
@@ -3127,7 +3128,7 @@ static int dgnc_tty_ioctl(struct tty_struct *tty, unsigned int cmd,
events |= (EV_IPU | EV_IPS);
rc = put_user(events, (unsigned int __user *) arg);
return rc;
@@ -3144,7 +3145,7 @@ static int dgnc_tty_ioctl(struct tty_struct *tty, unsigned int cmd,
int tdist;
int count;
* Get data from user first.
@@ -3152,7 +3153,7 @@ static int dgnc_tty_ioctl(struct tty_struct *tty, unsigned int cmd,
if (copy_from_user(&buf, uarg, sizeof(buf)))
return -EFAULT;
* Figure out how much data is in our RX and TX queues.
@@ -3190,7 +3191,7 @@ static int dgnc_tty_ioctl(struct tty_struct *tty, unsigned int cmd,
else
buf.txdone = 1;
return -EFAULT;
@@ -3198,7 +3199,7 @@ static int dgnc_tty_ioctl(struct tty_struct *tty, unsigned int cmd,
return 0;
default:
