staging: dgap: remove unused variable
Author: Aya Mahfouz <mahfouz.saif.elyazal@gmail.com>
This patch removes a variable that was simply used to
store the return value of a function call before
returning it.
The issue was detected and resolved using the following
coccinelle script:
identifier len,f;
-int len;
 ... when != len
     when strict
-len =
+return
        f(...);
-return len;
Signed-off-by: Aya Mahfouz
 drivers/staging/dgap/dgap.c | 5 +----
 1 file changed, 1 insertion(+), 4 deletions(-)
diff --git a/drivers/staging/dgap/dgap.c b/drivers/staging/dgap/dgap.c
index 7184747..914e332 100644
--- a/drivers/staging/dgap/dgap.c
+++ b/drivers/staging/dgap/dgap.c
@@ -3979,7 +3979,6 @@ static int dgap_get_modem_info(struct channel_t *ch, unsigned int __user *value)
 	int result;
 	u8 mstat;
 	ulong lock_flags;
-	int rc;
 	spin_lock_irqsave(&ch->ch_lock, lock_flags);
@@ -4004,9 +4003,7 @@ static int dgap_get_modem_info(struct channel_t *ch, unsigned int __user *value)
 	if (mstat & D_CD(ch))
 		result |= TIOCM_CD;
-	rc = put_user(result, value);
-	return rc;
+	return put_user(result, value);
BtrLinux
Privacy Overview
