drivers/staging/dgap/dgap.c | 88 ++++++++++++++++++++++-----------------------
1 file changed, 44 insertions(+), 44 deletions(-)
diff --git a/drivers/staging/dgap/dgap.c b/drivers/staging/dgap/dgap.c
index f7850f4..3cda302 100644
--- a/drivers/staging/dgap/dgap.c
+++ b/drivers/staging/dgap/dgap.c
@@ -1412,7 +1412,7 @@ static void dgap_parity_scan(struct channel_t *ch, unsigned char *cbuf,
case 0:
/* No FF seen yet */
- if (c == (unsigned char) '\377')
+ if (c == (unsigned char)'\377')
/* delete this character from stream */
ch->pscan_state = 1;
else {
@@ -1424,7 +1424,7 @@ static void dgap_parity_scan(struct channel_t *ch, unsigned char *cbuf,
case 1:
/* first FF seen */
- if (c == (unsigned char) '\377') {
+ if (c == (unsigned char)'\377') {
/* doubled ff, transform to single ff */
*cout++ = c;
*fout++ = TTY_NORMAL;
@@ -1836,7 +1836,7 @@ static int dgap_event(struct board_t *bd)
return -EIO;
- eaddr = (struct ev_t __iomem *) (vaddr + EVBUF);
+ eaddr = (struct ev_t __iomem *)(vaddr + EVBUF);
/* Get our head and tail */
head = readw(&(eaddr->ev_head));
@@ -1993,7 +1993,7 @@ next:
static void dgap_poll_tasklet(unsigned long data)
- struct board_t *bd = (struct board_t *) data;
+ struct board_t *bd = (struct board_t *)data;
ulong lock_flags;
char __iomem *vaddr;
u16 head, tail;
@@ -2026,7 +2026,7 @@ static void dgap_poll_tasklet(unsigned long data)
if (!bd->nasync)
goto out;
@@ -2261,7 +2261,7 @@ static void dgap_poll_handler(ulong dummy)
continue;
if (!brd->intr_running)
/* Call the real board poller directly */
- dgap_poll_tasklet((unsigned long) brd);
+ dgap_poll_tasklet((unsigned long)brd);
} else {
@@ -2314,7 +2314,7 @@ schedule_poller:
new_time = dgap_poll_time - jiffies;
- if ((ulong) new_time >= 2 * dgap_poll_tick) {
+ if ((ulong)new_time >= 2 * dgap_poll_tick) {
dgap_poll_time =
jiffies + dgap_jiffies_from_ms(dgap_poll_tick);
@@ -2368,7 +2368,7 @@ static void dgap_cmdb(struct channel_t *ch, u8 cmd, u8 byte1,
if (!vaddr)
return;
- cm_addr = (struct cm_t __iomem *) (vaddr + CMDBUF);
+ cm_addr = (struct cm_t __iomem *)(vaddr + CMDBUF);
head = readw(&(cm_addr->cm_head));
@@ -2383,7 +2383,7 @@ static void dgap_cmdb(struct channel_t *ch, u8 cmd, u8 byte1,
* Put the data in the circular command buffer.
writeb(cmd, (vaddr + head + CMDSTART + 0));
- writeb((u8) ch->ch_portnum, (vaddr + head + CMDSTART + 1));
+ writeb((u8)ch->ch_portnum, (vaddr + head + CMDSTART + 1));
writeb(byte1, (vaddr + head + CMDSTART + 2));
writeb(byte2, (vaddr + head + CMDSTART + 3));
@@ -2451,7 +2451,7 @@ static void dgap_cmdw(struct channel_t *ch, u8 cmd, u16 word, uint ncmds)
if (!vaddr)
return;
@@ -2466,8 +2466,8 @@ static void dgap_cmdw(struct channel_t *ch, u8 cmd, u16 word, uint ncmds)
- writew((u16) word, (vaddr + head + CMDSTART + 2));
+ writew((u16)word, (vaddr + head + CMDSTART + 2));
head = (head + 4) & (CMDMAX - CMDSTART - 4);
@@ -2533,7 +2533,7 @@ static void dgap_cmdw_ext(struct channel_t *ch, u16 cmd, u16 word, uint ncmds)
if (!vaddr)
return;
@@ -2549,19 +2549,19 @@ static void dgap_cmdw_ext(struct channel_t *ch, u16 cmd, u16 word, uint ncmds)
/* Write an FF to tell the FEP that we want an extended command */
- writeb((u8) 0xff, (vaddr + head + CMDSTART + 0));
+ writeb((u8)0xff, (vaddr + head + CMDSTART + 0));
- writew((u16) cmd, (vaddr + head + CMDSTART + 2));
+ writew((u16)cmd, (vaddr + head + CMDSTART + 2));
* If the second part of the command won't fit,
* put it at the beginning of the circular buffer.
if (((head + 4) >= ((CMDMAX - CMDSTART)) || (head & 03)))
- writew((u16) word, (vaddr + CMDSTART));
+ writew((u16)word, (vaddr + CMDSTART));
else
- writew((u16) word, (vaddr + head + CMDSTART + 4));
+ writew((u16)word, (vaddr + head + CMDSTART + 4));
head = (head + 8) & (CMDMAX - CMDSTART - 4);
@@ -2859,13 +2859,13 @@ static int dgap_param(struct channel_t *ch, struct board_t *bd, u32 un_type)
cflag &= 0xffff;
if (cflag != ch->ch_fepcflag) {
- ch->ch_fepcflag = (u16) (cflag & 0xffff);
+ ch->ch_fepcflag = (u16)(cflag & 0xffff);
* Okay to have channel and board
* locks held calling this
- dgap_cmdw(ch, SCFLAG, (u16) cflag, 0);
+ dgap_cmdw(ch, SCFLAG, (u16)cflag, 0);
/* Handle transition from B0 */
@@ -2906,7 +2906,7 @@ static int dgap_param(struct channel_t *ch, struct board_t *bd, u32 un_type)
ch->ch_fepiflag = iflag;
/* Okay to have channel and board locks held calling this */
- dgap_cmdw(ch, SIFLAG, (u16) ch->ch_fepiflag, 0);
+ dgap_cmdw(ch, SIFLAG, (u16)ch->ch_fepiflag, 0);
@@ -2931,7 +2931,7 @@ static int dgap_param(struct channel_t *ch, struct board_t *bd, u32 un_type)
ch->ch_hflow = hflow;
- dgap_cmdb(ch, SHFLOW, (u8) hflow, 0xff, 0);
+ dgap_cmdb(ch, SHFLOW, (u8)hflow, 0xff, 0);
@@ -2959,7 +2959,7 @@ static int dgap_param(struct channel_t *ch, struct board_t *bd, u32 un_type)
ch->ch_mostat = mval;
- dgap_cmdb(ch, SMODEM, (u8) mval, D_RTS(ch)|D_DTR(ch), 0);
+ dgap_cmdb(ch, SMODEM, (u8)mval, D_RTS(ch) | D_DTR(ch), 0);
@@ -3158,7 +3158,7 @@ static void dgap_tty_flush_buffer(struct tty_struct *tty)
ch->ch_flags &= ~CH_STOP;
head = readw(&(ch->ch_bs->tx_head));
- dgap_cmdw(ch, FLUSHTX, (u16) head, 0);
+ dgap_cmdw(ch, FLUSHTX, (u16)head, 0);
dgap_cmdw(ch, RESUMETX, 0, 0);
if (ch->ch_tun.un_flags & (UN_LOW|UN_EMPTY)) {
ch->ch_tun.un_flags &= ~(UN_LOW|UN_EMPTY);
@@ -3603,7 +3603,7 @@ static int dgap_tty_write(struct tty_struct *tty, const unsigned char *buf,
n -= remain;
vaddr = ch->ch_taddr + head;
- memcpy_toio(vaddr, (u8 *) buf, remain);
+ memcpy_toio(vaddr, (u8 *)buf, remain);
head = ch->ch_tstart;
buf += remain;
@@ -3616,7 +3616,7 @@ static int dgap_tty_write(struct tty_struct *tty, const unsigned char *buf,
remain = n;
head += remain;
@@ -3829,7 +3829,7 @@ static int dgap_tty_send_break(struct tty_struct *tty, int msec)
#if 0
dgap_cmdw(ch, SBREAK, (u16) SBREAK_TIME, 0);
#endif
- dgap_cmdw(ch, SBREAK, (u16) msec, 0);
+ dgap_cmdw(ch, SBREAK, (u16)msec, 0);
spin_unlock_irqrestore(&ch->ch_lock, lock_flags2);
spin_unlock_irqrestore(&bd->bd_lock, lock_flags);
@@ -4151,7 +4151,7 @@ static int dgap_tty_digisetedelay(struct channel_t *ch, struct board_t *bd,
spin_lock_irqsave(&bd->bd_lock, lock_flags);
spin_lock_irqsave(&ch->ch_lock, lock_flags2);
- writew((u16) new_digi, &(ch->ch_bs->edelay));
+ writew((u16)new_digi, &ch->ch_bs->edelay);
dgap_param(ch, bd, un->un_type);
@@ -4758,7 +4758,7 @@ static int dgap_tty_ioctl(struct tty_struct *tty, unsigned int cmd,
u16 head;
ulong lock_flags = 0;
ulong lock_flags2 = 0;
- void __user *uarg = (void __user *) arg;
+ void __user *uarg = (void __user *)arg;
if (!tty || tty->magic != TTY_MAGIC)
return -ENODEV;
@@ -4810,7 +4810,7 @@ static int dgap_tty_ioctl(struct tty_struct *tty, unsigned int cmd,
if (((cmd == TCSBRK) && (!arg)) || (cmd == TCSBRKP))
- dgap_cmdw(ch, SBREAK, (u16) SBREAK_TIME, 0);
+ dgap_cmdw(ch, SBREAK, (u16)SBREAK_TIME, 0);
@@ -4837,7 +4837,7 @@ static int dgap_tty_ioctl(struct tty_struct *tty, unsigned int cmd,
@@ -4864,7 +4864,7 @@ static int dgap_tty_ioctl(struct tty_struct *tty, unsigned int cmd,
@@ -4888,13 +4888,13 @@ static int dgap_tty_ioctl(struct tty_struct *tty, unsigned int cmd,
return put_user(C_CLOCAL(tty) ? 1 : 0,
- (unsigned long __user *) arg);
+ (unsigned long __user *)arg);
case TIOCSSOFTCAR:
- rc = get_user(arg, (unsigned long __user *) arg);
+ rc = get_user(arg, (unsigned long __user *)arg);
if (rc)
return rc;
@@ -4959,7 +4959,7 @@ static int dgap_tty_ioctl(struct tty_struct *tty, unsigned int cmd,
@@ -5984,7 +5984,7 @@ static int dgap_test_bios(struct board_t *brd)
brd->wait_for_bios = 0;
while (brd->wait_for_bios < 1000) {
/* Check to see if BIOS thinks board is good. (GD). */
- if (word == *(u16 *) "GD")
+ if (word == *(u16 *)"GD")
return 0;
msleep_interruptible(10);
brd->wait_for_bios++;
@@ -6070,12 +6070,12 @@ static int dgap_test_fep(struct board_t *brd)
brd->wait_for_fep = 0;
while (brd->wait_for_fep < 500) {
/* Check to see if FEP is up and running now. */
- if (word == *(u16 *) "OS") {
+ if (word == *(u16 *)"OS") {
* Check to see if the board can support FEP5+ commands.
word = readw(addr + FEP5_PLUS);
- if (word == *(u16 *) "5A")
+ if (word == *(u16 *)"5A")
brd->bd_flags |= BD_FEP5PLUS;
return 0;
@@ -6161,8 +6161,8 @@ static void dgap_do_conc_load(struct board_t *brd, u8 *uaddr, int len)
vaddr = brd->re_map_membase;
- offset = readw((u16 *) (vaddr + DOWNREQ));
- to_dp = (struct downld_t *) (vaddr + (int) offset);
+ offset = readw((u16 *)(vaddr + DOWNREQ));
+ to_dp = (struct downld_t *)(vaddr + (int)offset);
memcpy_toio(to_dp, uaddr, len);
/* Tell card we have data for it */
@@ -6621,7 +6621,7 @@ static int dgap_firmware_load(struct pci_dev *pdev, int card_type,
* is requesting a concentrator image from us.
if ((bd->type == PCX) || (bd->type == PEPC)) {
- chk_addr = (u16 *) (vaddr + DOWNREQ);
+ chk_addr = (u16 *)(vaddr + DOWNREQ);
/* Nonzero if FEP is requesting concentrator image. */
check = readw(chk_addr);
@@ -6636,7 +6636,7 @@ static int dgap_firmware_load(struct pci_dev *pdev, int card_type,
return ret;
/* Put concentrator firmware loading code here */
memcpy_toio(offset, fw->data, fw->size);
dgap_do_conc_load(brd, (char *)fw->data, fw->size)
@@ -6719,8 +6719,8 @@ static int dgap_tty_init(struct board_t *brd)
ch = brd->channels[0];
- bs = (struct bs_t __iomem *) ((ulong) vaddr + CHANBUF);
- cm = (struct cm_t __iomem *) ((ulong) vaddr + CMDBUF);
+ bs = (struct bs_t __iomem *)((ulong)vaddr + CHANBUF);
+ cm = (struct cm_t __iomem *)((ulong)vaddr + CMDBUF);
brd->bd_bs = bs; |
