staging: csr: use is_zero_ether_addr() instead of memcmp()
Author: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Using is_zero_ether_addr() instead of directly use
memcmp() to determine if the ethernet address is all
zeros.
spatch with a semantic match is used to found this problem.
(http://coccinelle.lip6.fr/)
Signed-off-by: Wei Yongjun
drivers/staging/csr/sme_wext.c | 4 +---
1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/drivers/staging/csr/sme_wext.c b/drivers/staging/csr/sme_wext.c
index 5689123..b58c0c6 100644
--- a/drivers/staging/csr/sme_wext.c
+++ b/drivers/staging/csr/sme_wext.c
@@ -1191,8 +1191,6 @@ unifi_siwap(struct net_device *dev, struct iw_request_info *info,
netInterface_priv_t *interfacePriv = (netInterface_priv_t *)netdev_priv(dev);
unifi_priv_t *priv = interfacePriv->privPtr;
int err = 0;
- const unsigned char zero_bssid[ETH_ALEN] = {0x00, 0x00, 0x00,
- 0x00, 0x00, 0x00};
func_enter();
@@ -1213,7 +1211,7 @@ unifi_siwap(struct net_device *dev, struct iw_request_info *info,
unifi_trace(priv, UDBG1, "unifi_siwap: asked for %pM\n",
wrqu->ap_addr.sa_data);
- if (!memcmp(wrqu->ap_addr.sa_data, zero_bssid, ETH_ALEN)) {
+ if (is_zero_ether_addr(wrqu->ap_addr.sa_data)) {
priv->ignore_bssid_join = FALSE;
err = sme_mgt_disconnect(priv);
if (err) { |
int err = 0;
func_enter();
if (err) {
