staging: comedi: Use macro DIV_ROUND_CLOSEST
Author: Bhaktipriya Shridhar <bhaktipriya96@gmail.com>
Occurences of the computation (x +d/2)/d can be replaced with
the macro DIV_ROUND_CLOSEST.
This was detected by the following Coccinelle script.
expression e1,e2;
- ((e1) + e2/2) / (e2)
+ DIV_ROUND_CLOSEST(e1,e2)
- ((e1) + (e2/2)) / (e2)
Since some lines exceeded the 80 character limit,
some changes were made by hand.
Signed-off-by: Bhaktipriya Shridhar
 drivers/staging/comedi/drivers/ni_mio_common.c | 28 +++++++++++---------------
 1 file changed, 12 insertions(+), 16 deletions(-)
diff --git a/drivers/staging/comedi/drivers/ni_mio_common.c b/drivers/staging/comedi/drivers/ni_mio_common.c
index 1c2abb3..8d8535b 100644
--- a/drivers/staging/comedi/drivers/ni_mio_common.c
+++ b/drivers/staging/comedi/drivers/ni_mio_common.c
@@ -2052,7 +2052,7 @@ static int ni_ns_to_timer(const struct comedi_device *dev, unsigned nanosec,
 	switch (flags & CMDF_ROUND_MASK) {
 	case CMDF_ROUND_NEAREST:
 	default:
-		divider = (nanosec + devpriv->clock_ns / 2) / devpriv->clock_ns;
+		divider = DIV_ROUND_CLOSEST(nanosec, devpriv->clock_ns);
 		break;
 	case CMDF_ROUND_DOWN:
 		divider = (nanosec) / devpriv->clock_ns;
@@ -4233,9 +4233,8 @@ static int ni_m_series_pwm_config(struct comedi_device *dev,
 	case INSN_CONFIG_PWM_OUTPUT:
 		switch (data[1]) {
-			up_count =
-			    (data[2] +
-			     devpriv->clock_ns / 2) / devpriv->clock_ns;
+			up_count = DIV_ROUND_CLOSEST(data[2],
+						     devpriv->clock_ns);
 			break;
 			up_count = data[2] / devpriv->clock_ns;
@@ -4250,9 +4249,8 @@ static int ni_m_series_pwm_config(struct comedi_device *dev,
 		switch (data[3]) {
-			down_count =
-			    (data[4] +
+			down_count = DIV_ROUND_CLOSEST(data[4],
 			break;
 			down_count = data[4] / devpriv->clock_ns;
@@ -4297,9 +4295,8 @@ static int ni_6143_pwm_config(struct comedi_device *dev,
 		switch (data[1]) {
-			up_count =
-			    (data[2] +
 			break;
@@ -4314,9 +4311,8 @@ static int ni_6143_pwm_config(struct comedi_device *dev,
 		switch (data[3]) {
-			down_count =
-			    (data[4] +
 			break;
@@ -4918,9 +4914,9 @@ static int ni_mseries_get_pll_parameters(unsigned reference_period_ns,
 	*freq_divider = best_div;
 	*freq_multiplier = best_mult;
-	*actual_period_ns =
-	    (best_period_picosec * fudge_factor_80_to_20Mhz +
-	     (pico_per_nano / 2)) / pico_per_nano;
+	*actual_period_ns = DIV_ROUND_CLOSEST(best_period_picosec *
+					      fudge_factor_80_to_20Mhz,
+					      pico_per_nano);
 	return 0;
BtrLinux
Privacy Overview
