staging: comedi: rewrite the right hand side of an assignment
Author: Aya Mahfouz <mahfouz.saif.elyazal@gmail.com>
This patch rewrites the right hand side of an assignment for
expressions of the form:
a = (a  b);
to be:
a = b;
where  = << | >>.
This issue was detected and resolved using the following
coccinelle script:
identifier i;
expression e;
-i = (i >> e);
+i >>= e;
identifier i;
expression e;
-i = (i << e);
+i <<= e;
Signed-off-by: Aya Mahfouz
 drivers/staging/comedi/drivers/rtd520.c | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/staging/comedi/drivers/rtd520.c b/drivers/staging/comedi/drivers/rtd520.c
index c94ad12..a7255d1 100644
--- a/drivers/staging/comedi/drivers/rtd520.c
+++ b/drivers/staging/comedi/drivers/rtd520.c
@@ -579,7 +579,7 @@ static int rtd_ai_rinsn(struct comedi_device *dev,
 		/* read data */
 		d = readw(devpriv->las1 + LAS1_ADC_FIFO);
-		d = d >> 3;	/* low 3 bits are marker lines */
+		d >>= 3;	/* low 3 bits are marker lines */
 		/* convert bipolar data to comedi unsigned data */
 		if (comedi_range_is_bipolar(s, range))
@@ -616,7 +616,7 @@ static int ai_read_n(struct comedi_device *dev, struct comedi_subdevice *s,
BtrLinux
Privacy Overview
