Staging: comedi: Remove parentheses around right side assignment
Author: Haneen Mohammed <hamohammed.sa@gmail.com>
Parentheses are not needed around the right hand side of an assignment.
This patch remove parenthese of such occurences. Issue was detected and
solved using the following coccinelle script:
@rule1@
identifier x, y, z;
expression E1, E2;
x = (y == z);
x = (E1 == E2);
 x =
Signed-off-by: Haneen Mohammed
 drivers/staging/comedi/drivers/addi_apci_3501.c | 4 ++--
 drivers/staging/comedi/drivers/ni_mio_common.c  | 8 ++++----
 drivers/staging/comedi/drivers/serial2002.c     | 4 ++--
 3 files changed, 8 insertions(+), 8 deletions(-)
diff --git a/drivers/staging/comedi/drivers/addi_apci_3501.c b/drivers/staging/comedi/drivers/addi_apci_3501.c
index b8f3366..babbdff 100644
--- a/drivers/staging/comedi/drivers/addi_apci_3501.c
+++ b/drivers/staging/comedi/drivers/addi_apci_3501.c
@@ -270,7 +270,7 @@ static irqreturn_t apci3501_interrupt(int irq, void *d)
 	/*  Disable Interrupt */
 	ul_Command1 = inl(dev->iobase + APCI3501_TIMER_CTRL_REG);
-	ul_Command1 = (ul_Command1 & 0xFFFFF9FDul);
+	ul_Command1 = ul_Command1 & 0xFFFFF9FDul;
 	outl(ul_Command1, dev->iobase + APCI3501_TIMER_CTRL_REG);
 	ui_Timer_AOWatchdog = inl(dev->iobase + APCI3501_TIMER_IRQ_REG) & 0x1;
@@ -282,7 +282,7 @@ static irqreturn_t apci3501_interrupt(int irq, void *d)
 	/* Enable Interrupt Send a signal to from kernel to user space */
 	send_sig(SIGIO, devpriv->tsk_Current, 0);
-	ul_Command1 = ((ul_Command1 & 0xFFFFF9FDul) | 1 << 1);
+	ul_Command1 = (ul_Command1 & 0xFFFFF9FDul) | 1 << 1;
 	inl(dev->iobase + APCI3501_TIMER_STATUS_REG);
diff --git a/drivers/staging/comedi/drivers/ni_mio_common.c b/drivers/staging/comedi/drivers/ni_mio_common.c
index 42fdedd..ecfd0544 100644
--- a/drivers/staging/comedi/drivers/ni_mio_common.c
+++ b/drivers/staging/comedi/drivers/ni_mio_common.c
@@ -1360,7 +1360,7 @@ static void get_last_sample_611x(struct comedi_device *dev)
 	/* Check if there's a single sample stuck in the FIFO */
 	if (ni_readb(dev, XXX_Status) & 0x80) {
 		dl = ni_readl(dev, ADC_FIFO_Data_611x);
-		data = (dl & 0xffff);
+		data = dl & 0xffff;
 		comedi_buf_write_samples(s, &data, 1);
@@ -1871,7 +1871,7 @@ static void ni_m_series_load_channelgain_list(struct comedi_device *dev,
 		chan = CR_CHAN(list[0]);
 		range = CR_RANGE(list[0]);
 		range_code = ni_gainlkup[board->gainlkup][range];
-		dither = ((list[0] & CR_ALT_FILTER) != 0);
+		dither = (list[0] & CR_ALT_FILTER) != 0;
 		bypass_bits = MSeries_AI_Bypass_Config_FIFO_Bit;
 		bypass_bits |= chan;
 		bypass_bits |=
@@ -1895,7 +1895,7 @@ static void ni_m_series_load_channelgain_list(struct comedi_device *dev,
 		chan = CR_CHAN(list[i]);
 		aref = CR_AREF(list[i]);
 		range = CR_RANGE(list[i]);
-		dither = ((list[i] & CR_ALT_FILTER) != 0);
+		dither = (list[i] & CR_ALT_FILTER) != 0;
 		devpriv->ai_offset[i] = 0;
@@ -2021,7 +2021,7 @@ static void ni_load_channelgain_list(struct comedi_device *dev,
 		/* fix the external/internal range differences */
 		range = ni_gainlkup[board->gainlkup][range];
diff --git a/drivers/staging/comedi/drivers/serial2002.c b/drivers/staging/comedi/drivers/serial2002.c
index 482a2a8..ad35ed6 100644
--- a/drivers/staging/comedi/drivers/serial2002.c
+++ b/drivers/staging/comedi/drivers/serial2002.c
@@ -143,8 +143,8 @@ static void serial2002_tty_read_poll_wait(struct file *f, int timeout)
 			break;
 		do_gettimeofday(&now);
-		elapsed = (1000000 * (now.tv_sec - start.tv_sec) +
-			  now.tv_usec - start.tv_usec);
+		elapsed = 1000000 * (now.tv_sec - start.tv_sec) +
+			  now.tv_usec - start.tv_usec;
 		if (elapsed > timeout)
 			break;
 		set_current_state(TASK_INTERRUPTIBLE);
BtrLinux
Privacy Overview
