Staging: comedi: Remove exceptional & on function name
Author: Shraddha Barke <shraddha.6596@gmail.com>
n this file, function names are otherwise used as pointers without &.
A simplified version of the Coccinelle semantic patch that makes this
change is as follows:
@r@
identifier f;
f(...) { ... }
identifier r.f;
- &f
+ f
Signed-off-by: Shraddha Barke
 drivers/staging/comedi/comedi_fops.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/staging/comedi/comedi_fops.c b/drivers/staging/comedi/comedi_fops.c
index ef4b58b..f341421 100644
--- a/drivers/staging/comedi/comedi_fops.c
+++ b/drivers/staging/comedi/comedi_fops.c
@@ -1341,7 +1341,7 @@ static int parse_insn(struct comedi_device *dev, struct comedi_insn *insn,
 			goto out;
 		/* This looks arbitrary.  It is. */
-		s->busy = &parse_insn;
+		s->busy = parse_insn;
 		switch (insn->insn) {
 		case INSN_READ:
 			ret = s->insn_read(dev, s, insn, data);
