Staging: comedi: Move a dereference below a NULL test
If the NULL test is necessary, then the dereference should be moved below
the NULL test.
The semantic patch that makes this change is as follows:
(http://www.emn.fr/x-info/coccinelle/).
@disable is_null@
identifier f;
expression E;
identifier fld;
statement S;
+ if (E == NULL) S
  f(...,E->fld,...);
- if (E == NULL) S
identifier f;
expression E;
identifier fld;
statement S;
+ if (!E) S
  f(...,E->fld,...);
- if (!E) S
Signed-off-by: Julia Lawall
 drivers/staging/comedi/drivers/usbduxfast.c | 8 ++++----
 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/staging/comedi/drivers/usbduxfast.c b/drivers/staging/comedi/drivers/usbduxfast.c
index 3ad3a08..cc42d7a 100644
--- a/drivers/staging/comedi/drivers/usbduxfast.c
+++ b/drivers/staging/comedi/drivers/usbduxfast.c
@@ -1675,15 +1675,15 @@ static int usbduxfast_detach(comedi_device * dev)
 	usbduxfastsub_t *usbduxfastsub_tmp;
-#ifdef CONFIG_COMEDI_DEBUG
-	printk("comedi%d: usbduxfast: detach usb device\n", dev->minor);
-#endif
 	if (!dev) {
 		printk("comedi?: usbduxfast: detach without dev variable...\n");
 		return -EFAULT;
+#ifdef CONFIG_COMEDI_DEBUG
+	printk("comedi%d: usbduxfast: detach usb device\n", dev->minor);
+#endif
 	usbduxfastsub_tmp = dev->private;
 	if (!usbduxfastsub_tmp) {
 		printk("comedi?: usbduxfast: detach without ptr to usbduxfastsub[]\n");
BtrLinux
Privacy Overview
