staging: comedi: drivers: Use DIV_ROUND_CLOSEST
Author: Amitoj Kaur Chawla <amitoj1606@gmail.com>
The kernel.h macro DIV_ROUND_CLOSEST performs the computation
`(x +d/2)/d` but is perhaps more readable.
The Coccinelle script used is as follows:
expression x,__divisor;
- (((x) + ((__divisor) / 2)) / (__divisor))
+ DIV_ROUND_CLOSEST(x,__divisor)
Signed-off-by: Amitoj Kaur Chawla
 drivers/staging/comedi/drivers/addi_apci_3xxx.c | 2 +-
 drivers/staging/comedi/drivers/amplc_pci230.c   | 2 +-
 drivers/staging/comedi/drivers/cb_pcidas64.c    | 4 ++--
 drivers/staging/comedi/drivers/dt282x.c         | 2 +-
 drivers/staging/comedi/drivers/dt3000.c         | 2 +-
 drivers/staging/comedi/drivers/ni_pcidio.c      | 2 +-
 6 files changed, 7 insertions(+), 7 deletions(-)
diff --git a/drivers/staging/comedi/drivers/addi_apci_3xxx.c b/drivers/staging/comedi/drivers/addi_apci_3xxx.c
index 995096c..b6af3eb 100644
--- a/drivers/staging/comedi/drivers/addi_apci_3xxx.c
+++ b/drivers/staging/comedi/drivers/addi_apci_3xxx.c
@@ -496,7 +496,7 @@ static int apci3xxx_ai_ns_to_timer(struct comedi_device *dev,
 		switch (flags & CMDF_ROUND_MASK) {
 		case CMDF_ROUND_NEAREST:
 		default:
-			timer = (*ns + base / 2) / base;
+			timer = DIV_ROUND_CLOSEST(*ns, base);
 			break;
 		case CMDF_ROUND_DOWN:
 			timer = *ns / base;
diff --git a/drivers/staging/comedi/drivers/amplc_pci230.c b/drivers/staging/comedi/drivers/amplc_pci230.c
index 4b39f69..d1fe88a 100644
--- a/drivers/staging/comedi/drivers/amplc_pci230.c
+++ b/drivers/staging/comedi/drivers/amplc_pci230.c
@@ -637,7 +637,7 @@ static unsigned int pci230_divide_ns(uint64_t ns, unsigned int timebase,
 	default:
-		div += (rem + (timebase / 2)) / timebase;
+		div += DIV_ROUND_CLOSEST(rem, timebase);
 		break;
 		break;
diff --git a/drivers/staging/comedi/drivers/cb_pcidas64.c b/drivers/staging/comedi/drivers/cb_pcidas64.c
index d33b8fe..e918d42 100644
--- a/drivers/staging/comedi/drivers/cb_pcidas64.c
+++ b/drivers/staging/comedi/drivers/cb_pcidas64.c
@@ -1376,7 +1376,7 @@ static int set_ai_fifo_segment_length(struct comedi_device *dev,
 		num_entries = fifo->max_segment_length;
 	/*  1 == 256 entries, 2 == 512 entries, etc */
-	num_increments = (num_entries + increment_size / 2) / increment_size;
+	num_increments = DIV_ROUND_CLOSEST(num_entries, increment_size);
 	bits = (~(num_increments - 1)) & fifo->fifo_size_reg_mask;
 	devpriv->fifo_size_bits &= ~fifo->fifo_size_reg_mask;
@@ -2004,7 +2004,7 @@ static unsigned int get_divisor(unsigned int ns, unsigned int flags)
 		break;
 	default:
-		divisor = (ns + TIMER_BASE / 2) / TIMER_BASE;
+		divisor = DIV_ROUND_CLOSEST(ns, TIMER_BASE);
 		break;
 	return divisor;
diff --git a/drivers/staging/comedi/drivers/dt282x.c b/drivers/staging/comedi/drivers/dt282x.c
index 5a536a0..6c26e09 100644
--- a/drivers/staging/comedi/drivers/dt282x.c
+++ b/drivers/staging/comedi/drivers/dt282x.c
@@ -371,7 +371,7 @@ static unsigned int dt282x_ns_to_timer(unsigned int *ns, unsigned int flags)
 		default:
-			divider = (*ns + base / 2) / base;
+			divider = DIV_ROUND_CLOSEST(*ns, base);
 			break;
 			divider = (*ns) / base;
diff --git a/drivers/staging/comedi/drivers/dt3000.c b/drivers/staging/comedi/drivers/dt3000.c
index ab7a332..19e0b7b 100644
--- a/drivers/staging/comedi/drivers/dt3000.c
+++ b/drivers/staging/comedi/drivers/dt3000.c
@@ -361,7 +361,7 @@ static int dt3k_ns_to_timer(unsigned int timer_base, unsigned int *nanosec,
 		default:
-			divider = (*nanosec + base / 2) / base;
+			divider = DIV_ROUND_CLOSEST(*nanosec, base);
 			break;
 			divider = (*nanosec) / base;
diff --git a/drivers/staging/comedi/drivers/ni_pcidio.c b/drivers/staging/comedi/drivers/ni_pcidio.c
index ac79099..67b9f22 100644
--- a/drivers/staging/comedi/drivers/ni_pcidio.c
+++ b/drivers/staging/comedi/drivers/ni_pcidio.c
@@ -525,7 +525,7 @@ static int ni_pcidio_ns_to_timer(int *nanosec, unsigned int flags)
 	default:
 		break;
BtrLinux
Privacy Overview
