staging: comedi: drivers: Remove use of deprecated pci API
Author: Amitoj Kaur Chawla <amitoj1606@gmail.com>
Replace pci_[alloc|free]_consistent occurences with
dma_[alloc|free]_coherent.
The Coccinelle semantic patch that was used to make some of these
changes is as follows:
@deprecated@
idexpression id;
position p;
  pci_dma_supported@p ( id, ...)
  pci_alloc_consistent@p ( id, ...)
@bad1@
idexpression id;
position deprecated.p;
...when != &id->dev
   when != pci_get_drvdata ( id )
   when != pci_enable_device ( id )
@depends on !bad1@
idexpression id;
expression direction;
- pci_dma_supported@p ( id,
+ dma_supported ( &id->dev,
+ , GFP_KERNEL
- pci_alloc_consistent@p ( id,
+ dma_alloc_coherent ( &id->dev,
+ , GFP_KERNEL
alloc_and_init_dma_members does not affect the interrupt status and is
only called by auto_attach, which also does not affect the interrupt
status. auto_attach() also contains a call to comedi_alloc_devpriv()
which calls kzalloc with GFP_KERNEL flag.  Thus, there seems to be no
danger that dma_alloc_coherent can be called with interrupts turned
off, and GFP_KERNEL can be used.
Signed-off-by: Amitoj Kaur Chawla
 drivers/staging/comedi/drivers/cb_pcidas64.c | 64 +++++++++++++++-------------
 1 file changed, 34 insertions(+), 30 deletions(-)
diff --git a/drivers/staging/comedi/drivers/cb_pcidas64.c b/drivers/staging/comedi/drivers/cb_pcidas64.c
index e918d42..c773b8c 100644
--- a/drivers/staging/comedi/drivers/cb_pcidas64.c
+++ b/drivers/staging/comedi/drivers/cb_pcidas64.c
@@ -1480,35 +1480,39 @@ static int alloc_and_init_dma_members(struct comedi_device *dev)
 	/*  allocate pci dma buffers */
 	for (i = 0; i < ai_dma_ring_count(board); i++) {
 		devpriv->ai_buffer[i] =
-			pci_alloc_consistent(pcidev, DMA_BUFFER_SIZE,
-					     &devpriv->ai_buffer_bus_addr[i]);
+			dma_alloc_coherent(&pcidev->dev, DMA_BUFFER_SIZE,
+					   &devpriv->ai_buffer_bus_addr[i],
+					   GFP_KERNEL);
 		if (!devpriv->ai_buffer[i])
 			return -ENOMEM;
 	for (i = 0; i < AO_DMA_RING_COUNT; i++) {
 		if (ao_cmd_is_supported(board)) {
 			devpriv->ao_buffer[i] =
-						     &devpriv->
-						      ao_buffer_bus_addr[i]);
+						   DMA_BUFFER_SIZE,
+						   &devpriv->
+						   ao_buffer_bus_addr[i],
+						   GFP_KERNEL);
 			if (!devpriv->ao_buffer[i])
 				return -ENOMEM;
 	/*  allocate dma descriptors */
 	devpriv->ai_dma_desc =
-		pci_alloc_consistent(pcidev, sizeof(struct plx_dma_desc) *
-				     ai_dma_ring_count(board),
-				     &devpriv->ai_dma_desc_bus_addr);
+		dma_alloc_coherent(&pcidev->dev, sizeof(struct plx_dma_desc) *
+				   ai_dma_ring_count(board),
+				   &devpriv->ai_dma_desc_bus_addr, GFP_KERNEL);
 	if (!devpriv->ai_dma_desc)
 		return -ENOMEM;
 		devpriv->ao_dma_desc =
-					     sizeof(struct plx_dma_desc) *
-					     AO_DMA_RING_COUNT,
-					     &devpriv->ao_dma_desc_bus_addr);
+					   sizeof(struct plx_dma_desc) *
+					   AO_DMA_RING_COUNT,
+					   &devpriv->ao_dma_desc_bus_addr,
+					   GFP_KERNEL);
 		if (!devpriv->ao_dma_desc)
 			return -ENOMEM;
@@ -1564,31 +1568,31 @@ static void cb_pcidas64_free_dma(struct comedi_device *dev)
 	/* free pci dma buffers */
 		if (devpriv->ai_buffer[i])
-			pci_free_consistent(pcidev,
-					    DMA_BUFFER_SIZE,
-					    devpriv->ai_buffer[i],
-					    devpriv->ai_buffer_bus_addr[i]);
+			dma_free_coherent(&pcidev->dev,
+					  DMA_BUFFER_SIZE,
+					  devpriv->ai_buffer[i],
+					  devpriv->ai_buffer_bus_addr[i]);
 		if (devpriv->ao_buffer[i])
-					    DMA_BUFFER_SIZE,
-					    devpriv->ao_buffer[i],
-					    devpriv->ao_buffer_bus_addr[i]);
+					  DMA_BUFFER_SIZE,
+					  devpriv->ao_buffer[i],
+					  devpriv->ao_buffer_bus_addr[i]);
 	/* free dma descriptors */
 	if (devpriv->ai_dma_desc)
-				    devpriv->ai_dma_desc,
-				    devpriv->ai_dma_desc_bus_addr);
+				  devpriv->ai_dma_desc,
+				  devpriv->ai_dma_desc_bus_addr);
 	if (devpriv->ao_dma_desc)
-				    devpriv->ao_dma_desc,
-				    devpriv->ao_dma_desc_bus_addr);
+				  devpriv->ao_dma_desc,
+				  devpriv->ao_dma_desc_bus_addr);
 static inline void warn_external_queue(struct comedi_device *dev)
BtrLinux
Privacy Overview
