staging: comedi: drivers: ni_mio_common: Prefer using macro DIV_ROUND_UP
Author: Bhaktipriya Shridhar <bhaktipriya96@gmail.com>
The macro DIV_ROUND_UP performs the computation
(((n) + (d) - 1) /(d)). It clarifies the divisor calculations.
This was done using the coccinelle script:
expression e1;
expression e2;
- ((e1) + e2 - 1) / (e2)
+ DIV_ROUND_UP(e1,e2)
- ((e1) + (e2 - 1)) / (e2)
Signed-off-by: Bhaktipriya Shridhar
drivers/staging/comedi/drivers/ni_mio_common.c | 14 +++++---------
1 file changed, 5 insertions(+), 9 deletions(-)
diff --git a/drivers/staging/comedi/drivers/ni_mio_common.c b/drivers/staging/comedi/drivers/ni_mio_common.c
index 8d8535b..d1226c9 100644
--- a/drivers/staging/comedi/drivers/ni_mio_common.c
+++ b/drivers/staging/comedi/drivers/ni_mio_common.c
@@ -2058,7 +2058,7 @@ static int ni_ns_to_timer(const struct comedi_device *dev, unsigned nanosec,
divider = (nanosec) / devpriv->clock_ns;
break;
case CMDF_ROUND_UP:
- divider = (nanosec + devpriv->clock_ns - 1) / devpriv->clock_ns;
+ divider = DIV_ROUND_UP(nanosec, devpriv->clock_ns);
break;
return divider - 1;
@@ -4241,8 +4241,7 @@ static int ni_m_series_pwm_config(struct comedi_device *dev,
break;
case CMDF_ROUND_UP:
up_count =
- (data[2] + devpriv->clock_ns -
+ DIV_ROUND_UP(data[2], devpriv->clock_ns);
break;
default:
return -EINVAL;
@@ -4257,8 +4256,7 @@ static int ni_m_series_pwm_config(struct comedi_device *dev,
break;
case CMDF_ROUND_UP:
down_count =
- (data[4] + devpriv->clock_ns -
+ DIV_ROUND_UP(data[4], devpriv->clock_ns);
break;
default:
return -EINVAL;
@@ -4303,8 +4301,7 @@ static int ni_6143_pwm_config(struct comedi_device *dev,
break;
case CMDF_ROUND_UP:
up_count =
break;
default:
return -EINVAL;
@@ -4319,8 +4316,7 @@ static int ni_6143_pwm_config(struct comedi_device *dev,
break;
case CMDF_ROUND_UP:
down_count =
break;
default:
return -EINVAL; |
break;
case CMDF_ROUND_UP:
break;
return divider - 1;
break;
case CMDF_ROUND_UP:
up_count =
break;
default:
return -EINVAL;
break;
case CMDF_ROUND_UP:
down_count =
break;
default:
return -EINVAL;
break;
case CMDF_ROUND_UP:
up_count =
break;
default:
return -EINVAL;
break;
case CMDF_ROUND_UP:
down_count =
break;
default:
return -EINVAL;
