staging: comedi: drivers: gsc_hpdi: Remove use of deprecated pci API
Author: Amitoj Kaur Chawla <amitoj1606@gmail.com>
Replace pci_[alloc|free]_consistent occurences with
dma_[alloc|free]_coherent.
The Coccinelle semantic patch that was used to make some of these
changes is as follows:
@deprecated@
idexpression id;
position p;
  pci_dma_supported@p ( id, ...)
  pci_alloc_consistent@p ( id, ...)
@bad1@
idexpression id;
position deprecated.p;
...when != &id->dev
   when != pci_get_drvdata ( id )
   when != pci_enable_device ( id )
@depends on !bad1@
idexpression id;
expression direction;
- pci_dma_supported@p ( id,
+ dma_supported ( &id->dev,
+ , GFP_KERNEL
- pci_alloc_consistent@p ( id,
+ dma_alloc_coherent ( &id->dev,
+ , GFP_KERNEL
gsc_hpdi_auto_attach does not affect interrupt status but contains a
call to comedi_alloc_devpriv() which calls kzalloc with GFP_KERNEL flag.
Thus, there seems to be no danger that dma_alloc_coherent can be called
with interrupts turned off, and GFP_KERNEL can be used.
Signed-off-by: Amitoj Kaur Chawla
 drivers/staging/comedi/drivers/gsc_hpdi.c | 32 ++++++++++++++++---------------
 1 file changed, 17 insertions(+), 15 deletions(-)
diff --git a/drivers/staging/comedi/drivers/gsc_hpdi.c b/drivers/staging/comedi/drivers/gsc_hpdi.c
index 46ca5d9..63b5cbc 100644
--- a/drivers/staging/comedi/drivers/gsc_hpdi.c
+++ b/drivers/staging/comedi/drivers/gsc_hpdi.c
@@ -499,18 +499,18 @@ static void gsc_hpdi_free_dma(struct comedi_device *dev)
 	/* free pci dma buffers */
 	for (i = 0; i < NUM_DMA_BUFFERS; i++) {
 		if (devpriv->dio_buffer[i])
-			pci_free_consistent(pcidev,
-					    DMA_BUFFER_SIZE,
-					    devpriv->dio_buffer[i],
-					    devpriv->dio_buffer_phys_addr[i]);
+			dma_free_coherent(&pcidev->dev,
+					  DMA_BUFFER_SIZE,
+					  devpriv->dio_buffer[i],
+					  devpriv->dio_buffer_phys_addr[i]);
 	/* free dma descriptors */
 	if (devpriv->dma_desc)
-				    sizeof(struct plx_dma_desc) *
-				    NUM_DMA_DESCRIPTORS,
-				    devpriv->dma_desc,
-				    devpriv->dma_desc_phys_addr);
+				  sizeof(struct plx_dma_desc) *
+				  NUM_DMA_DESCRIPTORS,
+				  devpriv->dma_desc,
+				  devpriv->dma_desc_phys_addr);
 static int gsc_hpdi_init(struct comedi_device *dev)
@@ -630,14 +630,16 @@ static int gsc_hpdi_auto_attach(struct comedi_device *dev,
 	/* allocate pci dma buffers */
 		devpriv->dio_buffer[i] =
-		    pci_alloc_consistent(pcidev, DMA_BUFFER_SIZE,
-					 &devpriv->dio_buffer_phys_addr[i]);
+		    dma_alloc_coherent(&pcidev->dev, DMA_BUFFER_SIZE,
+				       &devpriv->dio_buffer_phys_addr[i],
+				       GFP_KERNEL);
 	/* allocate dma descriptors */
-	devpriv->dma_desc = pci_alloc_consistent(pcidev,
-						 &devpriv->dma_desc_phys_addr);
+	devpriv->dma_desc = dma_alloc_coherent(&pcidev->dev,
+					       &devpriv->dma_desc_phys_addr,
+					       GFP_KERNEL);
 	if (devpriv->dma_desc_phys_addr & 0xf) {
 		dev_warn(dev->class_dev,
 			 " dma descriptors not quad-word aligned (bug)\n");
BtrLinux
Privacy Overview
