staging: comedi: change bool assignment to true
Author: Teodora Baluta <teobaluta@gmail.com>
This is a minor fix that was suggested by coccinelle. When defined as a
bool, a variable should use true/false rather than 1/0.
Signed-off-by: Teodora Baluta
Reviewed-by: Lisa Nguyen
Reviewed-by: Peter P Waskiewicz Jr
 drivers/staging/comedi/drivers/amplc_dio200_common.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/staging/comedi/drivers/amplc_dio200_common.c b/drivers/staging/comedi/drivers/amplc_dio200_common.c
index 2e4bf28..9c9559f 100644
--- a/drivers/staging/comedi/drivers/amplc_dio200_common.c
+++ b/drivers/staging/comedi/drivers/amplc_dio200_common.c
@@ -513,7 +513,7 @@ static int dio200_subdev_intr_cmd(struct comedi_device *dev,
 	int event = 0;
 	spin_lock_irqsave(&subpriv->spinlock, flags);
-	subpriv->active = 1;
+	subpriv->active = true;
 	/* Set up end of acquisition. */
 	switch (cmd->stop_src) {
BtrLinux
Privacy Overview
