staging: bcm: optimize kmalloc to kzalloc
Author: Alexander Beregalov <a.beregalov@gmail.com>
Use kzalloc rather than kmalloc followed by memset with 0.
Found by coccinelle.
Signed-off-by: Alexander Beregalov
 drivers/staging/bcm/Bcmchar.c | 4 +---
 drivers/staging/bcm/Misc.c    | 6 ++----
 2 files changed, 3 insertions(+), 7 deletions(-)
diff --git a/drivers/staging/bcm/Bcmchar.c b/drivers/staging/bcm/Bcmchar.c
index 3d9055a..867dbf1 100644
--- a/drivers/staging/bcm/Bcmchar.c
+++ b/drivers/staging/bcm/Bcmchar.c
@@ -19,12 +19,10 @@ static int bcm_char_open(struct inode *inode, struct file * filp)
 	PPER_TARANG_DATA    pTarang = NULL;
 	Adapter = GET_BCM_ADAPTER(gblpnetdev);
-	pTarang = (PPER_TARANG_DATA)kmalloc(sizeof(PER_TARANG_DATA),
-					    GFP_KERNEL);
+	pTarang = kzalloc(sizeof(PER_TARANG_DATA), GFP_KERNEL);
 	if (!pTarang)
 		return -ENOMEM;
-	memset(pTarang, 0, sizeof(PER_TARANG_DATA));
 	pTarang->Adapter = Adapter;
 	pTarang->RxCntrlMsgBitMask = 0xFFFFFFFF & ~(1 << 0xB);
diff --git a/drivers/staging/bcm/Misc.c b/drivers/staging/bcm/Misc.c
index f585aae..d624f35 100644
--- a/drivers/staging/bcm/Misc.c
+++ b/drivers/staging/bcm/Misc.c
@@ -498,13 +498,12 @@ VOID LinkMessage(PMINI_ADAPTER Adapter)
 	BCM_DEBUG_PRINT(Adapter,DBG_TYPE_OTHERS, LINK_UP_MSG, DBG_LVL_ALL, "=====>");
 	if(Adapter->LinkStatus == SYNC_UP_REQUEST && Adapter->AutoSyncup)
-		pstLinkRequest=kmalloc(sizeof(LINK_REQUEST), GFP_ATOMIC);
+		pstLinkRequest = kzalloc(sizeof(LINK_REQUEST), GFP_ATOMIC);
 		if(!pstLinkRequest)
 			BCM_DEBUG_PRINT(Adapter,DBG_TYPE_OTHERS, LINK_UP_MSG, DBG_LVL_ALL, "Can not allocate memory for Link request!");
 			return;
-		memset(pstLinkRequest,0,sizeof(LINK_REQUEST));
 		//sync up request...
 		Adapter->LinkStatus = WAIT_FOR_SYNC;// current link status
 		BCM_DEBUG_PRINT(Adapter,DBG_TYPE_OTHERS, LINK_UP_MSG, DBG_LVL_ALL, "Requesting For SyncUp...");
@@ -516,13 +515,12 @@ VOID LinkMessage(PMINI_ADAPTER Adapter)
 	else if(Adapter->LinkStatus == PHY_SYNC_ACHIVED && Adapter->AutoLinkUp)
 		if(!pstLinkRequest)
 			return;
 		//LINK_UP_REQUEST
 		BCM_DEBUG_PRINT(Adapter,DBG_TYPE_OTHERS, LINK_UP_MSG, DBG_LVL_ALL, "Requesting For LinkUp...");
 		pstLinkRequest->szData[0]=LINK_UP_REQ_PAYLOAD;
BtrLinux
Privacy Overview
