Staging: ARRAY_SIZE changes
Author: Stoyan Gaydarov <sgayda2@uiuc.edu>
These changes were a direct result of using a semantic patch
More information can be found at http://www.emn.fr/x-info/coccinelle/
Signed-off-by: Stoyan Gaydarov
 drivers/staging/comedi/drivers/amplc_pci230.c      | 2 +-
 drivers/staging/comedi/drivers/cb_das16_cs.c       | 2 +-
 drivers/staging/comedi/drivers/das08_cs.c          | 3 +--
 drivers/staging/comedi/drivers/ni_6527.c           | 2 +-
 drivers/staging/comedi/drivers/ni_65xx.c           | 2 +-
 drivers/staging/comedi/drivers/ni_660x.c           | 2 +-
 drivers/staging/comedi/drivers/ni_670x.c           | 2 +-
 drivers/staging/comedi/drivers/ni_atmio16d.c       | 2 +-
 drivers/staging/comedi/drivers/ni_pcidio.c         | 2 +-
 drivers/staging/comedi/drivers/ni_pcimio.c         | 2 +-
 drivers/staging/comedi/drivers/pcmad.c             | 2 +-
 drivers/staging/comedi/drivers/poc.c               | 2 +-
 drivers/staging/epl/EplDllk.c                      | 2 +-
 drivers/staging/epl/proc_fs.c                      | 4 ++--
 drivers/staging/line6/driver.c                     | 2 +-
 drivers/staging/meilhaus/me0600_device.h           | 2 +-
 drivers/staging/meilhaus/me0900_device.h           | 2 +-
 drivers/staging/meilhaus/me1400_device.h           | 2 +-
 drivers/staging/meilhaus/me1600_device.h           | 2 +-
 drivers/staging/meilhaus/me4600_device.h           | 2 +-
 drivers/staging/meilhaus/me6000_device.h           | 2 +-
 drivers/staging/meilhaus/me8100_device.h           | 2 +-
 drivers/staging/meilhaus/me8200_device.h           | 2 +-
 drivers/staging/meilhaus/metempl_device.h          | 2 +-
 drivers/staging/rtl8187se/r8180_wx.c               | 6 +++---
 drivers/staging/rtl8192su/ieee80211/ieee80211_wx.c | 2 +-
 drivers/staging/rtl8192su/r8192U_wx.c              | 4 ++--
 drivers/staging/slicoss/slicoss.c                  | 2 +-
 drivers/staging/sxg/sxg.c                          | 2 +-
 29 files changed, 33 insertions(+), 34 deletions(-)
diff --git a/drivers/staging/comedi/drivers/amplc_pci230.c b/drivers/staging/comedi/drivers/amplc_pci230.c
index c4d8c4c..091a1a5 100644
--- a/drivers/staging/comedi/drivers/amplc_pci230.c
+++ b/drivers/staging/comedi/drivers/amplc_pci230.c
@@ -513,7 +513,7 @@ MODULE_DEVICE_TABLE(pci, pci230_pci_table);
  * Useful for shorthand access to the particular board structure
-#define n_pci230_boards (sizeof(pci230_boards)/sizeof(pci230_boards[0]))
+#define n_pci230_boards ARRAY_SIZE(pci230_boards)
 #define thisboard ((const struct pci230_board *)dev->board_ptr)
 /* this structure is for data unique to this hardware driver.  If
diff --git a/drivers/staging/comedi/drivers/cb_das16_cs.c b/drivers/staging/comedi/drivers/cb_das16_cs.c
index 2f7aa3b..12d12b4 100644
--- a/drivers/staging/comedi/drivers/cb_das16_cs.c
+++ b/drivers/staging/comedi/drivers/cb_das16_cs.c
@@ -78,7 +78,7 @@ static const struct das16cs_board das16cs_boards[] = {
-#define n_boards (sizeof(das16cs_boards)/sizeof(das16cs_boards[0]))
+#define n_boards ARRAY_SIZE(das16cs_boards)
 #define thisboard ((const struct das16cs_board *)dev->board_ptr)
 struct das16cs_private {
diff --git a/drivers/staging/comedi/drivers/das08_cs.c b/drivers/staging/comedi/drivers/das08_cs.c
index 74fcc10..9cab21e 100644
--- a/drivers/staging/comedi/drivers/das08_cs.c
+++ b/drivers/staging/comedi/drivers/das08_cs.c
@@ -65,8 +65,7 @@ static struct comedi_driver driver_das08_cs = {
 	.attach = das08_cs_attach,
 	.detach = das08_common_detach,
 	.board_name = &das08_cs_boards[0].name,
-	.num_names = sizeof(das08_cs_boards) /
-	    sizeof(struct das08_board_struct),
+	.num_names = ARRAY_SIZE(das08_cs_boards),
 	.offset = sizeof(struct das08_board_struct),
diff --git a/drivers/staging/comedi/drivers/ni_6527.c b/drivers/staging/comedi/drivers/ni_6527.c
index 7a49dfc..b37ef37 100644
--- a/drivers/staging/comedi/drivers/ni_6527.c
+++ b/drivers/staging/comedi/drivers/ni_6527.c
@@ -103,7 +103,7 @@ static const struct ni6527_board ni6527_boards[] = {
-#define n_ni6527_boards (sizeof(ni6527_boards)/sizeof(ni6527_boards[0]))
+#define n_ni6527_boards ARRAY_SIZE(ni6527_boards)
 #define this_board ((const struct ni6527_board *)dev->board_ptr)
 static DEFINE_PCI_DEVICE_TABLE(ni6527_pci_table) = {
diff --git a/drivers/staging/comedi/drivers/ni_65xx.c b/drivers/staging/comedi/drivers/ni_65xx.c
index 8079c41..6b118c1 100644
--- a/drivers/staging/comedi/drivers/ni_65xx.c
+++ b/drivers/staging/comedi/drivers/ni_65xx.c
@@ -246,7 +246,7 @@ static const struct ni_65xx_board ni_65xx_boards[] = {
-#define n_ni_65xx_boards (sizeof(ni_65xx_boards)/sizeof(ni_65xx_boards[0]))
+#define n_ni_65xx_boards ARRAY_SIZE(ni_65xx_boards)
 static inline const struct ni_65xx_board *board(struct comedi_device *dev)
 	return dev->board_ptr;
diff --git a/drivers/staging/comedi/drivers/ni_660x.c b/drivers/staging/comedi/drivers/ni_660x.c
index 772c937..404d3c5 100644
--- a/drivers/staging/comedi/drivers/ni_660x.c
+++ b/drivers/staging/comedi/drivers/ni_660x.c
@@ -454,7 +454,7 @@ static inline const struct ni_660x_board *board(struct comedi_device *dev)
-#define n_ni_660x_boards (sizeof(ni_660x_boards)/sizeof(ni_660x_boards[0]))
+#define n_ni_660x_boards ARRAY_SIZE(ni_660x_boards)
 static int ni_660x_attach(struct comedi_device *dev,
 			  struct comedi_devconfig *it);
diff --git a/drivers/staging/comedi/drivers/ni_670x.c b/drivers/staging/comedi/drivers/ni_670x.c
index 89ce5b8..9b43547 100644
--- a/drivers/staging/comedi/drivers/ni_670x.c
+++ b/drivers/staging/comedi/drivers/ni_670x.c
@@ -111,7 +111,7 @@ struct ni_670x_private {
 #define devpriv ((struct ni_670x_private *)dev->private)
-#define n_ni_670x_boards (sizeof(ni_670x_boards)/sizeof(ni_670x_boards[0]))
+#define n_ni_670x_boards ARRAY_SIZE(ni_670x_boards)
 static int ni_670x_attach(struct comedi_device *dev,
diff --git a/drivers/staging/comedi/drivers/ni_atmio16d.c b/drivers/staging/comedi/drivers/ni_atmio16d.c
index cde30b7..901833d 100644
--- a/drivers/staging/comedi/drivers/ni_atmio16d.c
+++ b/drivers/staging/comedi/drivers/ni_atmio16d.c
@@ -121,7 +121,7 @@ static const struct atmio16_board_t atmio16_boards[] = {
-#define n_atmio16_boards sizeof(atmio16_boards)/sizeof(atmio16_boards[0])
+#define n_atmio16_boards ARRAY_SIZE(atmio16_boards)
 #define boardtype ((const struct atmio16_board_t *)dev->board_ptr)
diff --git a/drivers/staging/comedi/drivers/ni_pcidio.c b/drivers/staging/comedi/drivers/ni_pcidio.c
index 15148d1..52b2eca 100644
--- a/drivers/staging/comedi/drivers/ni_pcidio.c
+++ b/drivers/staging/comedi/drivers/ni_pcidio.c
@@ -374,7 +374,7 @@ static const struct nidio_board nidio_boards[] = {
-#define n_nidio_boards (sizeof(nidio_boards)/sizeof(nidio_boards[0]))
+#define n_nidio_boards ARRAY_SIZE(nidio_boards)
 #define this_board ((const struct nidio_board *)dev->board_ptr)
 static DEFINE_PCI_DEVICE_TABLE(ni_pcidio_pci_table) = {
diff --git a/drivers/staging/comedi/drivers/ni_pcimio.c b/drivers/staging/comedi/drivers/ni_pcimio.c
index 0dc6392..19d8755 100644
--- a/drivers/staging/comedi/drivers/ni_pcimio.c
+++ b/drivers/staging/comedi/drivers/ni_pcimio.c
@@ -1208,7 +1208,7 @@ static const struct ni_board_struct ni_boards[] = {
-#define n_pcimio_boards ((sizeof(ni_boards)/sizeof(ni_boards[0])))
+#define n_pcimio_boards ARRAY_SIZE(ni_boards)
 static int pcimio_attach(struct comedi_device *dev,
diff --git a/drivers/staging/comedi/drivers/pcmad.c b/drivers/staging/comedi/drivers/pcmad.c
index 7368bf3..acac670 100644
--- a/drivers/staging/comedi/drivers/pcmad.c
+++ b/drivers/staging/comedi/drivers/pcmad.c
@@ -69,7 +69,7 @@ static const struct pcmad_board_struct pcmad_boards[] = {
 #define this_board ((const struct pcmad_board_struct *)(dev->board_ptr))
-#define n_pcmad_boards (sizeof(pcmad_boards)/sizeof(pcmad_boards[0]))
+#define n_pcmad_boards ARRAY_SIZE(pcmad_boards)
 struct pcmad_priv_struct {
 	int differential;
diff --git a/drivers/staging/comedi/drivers/poc.c b/drivers/staging/comedi/drivers/poc.c
index 729a0d8..d23e588 100644
--- a/drivers/staging/comedi/drivers/poc.c
+++ b/drivers/staging/comedi/drivers/poc.c
@@ -102,7 +102,7 @@ static const struct boarddef_struct boards[] = {
-#define n_boards (sizeof(boards)/sizeof(boards[0]))
+#define n_boards ARRAY_SIZE(boards)
 #define this_board ((const struct boarddef_struct *)dev->board_ptr)
 static struct comedi_driver driver_poc = {
diff --git a/drivers/staging/epl/EplDllk.c b/drivers/staging/epl/EplDllk.c
index 25d2c34..0572c3d 100644
--- a/drivers/staging/epl/EplDllk.c
+++ b/drivers/staging/epl/EplDllk.c
@@ -328,7 +328,7 @@ tEplKernel EplDllkAddInstance(tEplDllkInitParam * pInitParam_p)
 	// initialize and link pointers in instance structure to frame tables
 	EplDllkInstance_g.m_pTxBuffer = aEplDllkTxBuffer_l;
 	EplDllkInstance_g.m_uiMaxTxFrames =
-	    sizeof(aEplDllkTxBuffer_l) / sizeof(tEdrvTxBuffer);
+	    ARRAY_SIZE(aEplDllkTxBuffer_l);
 	// initialize state
 	EplDllkInstance_g.m_DllState = kEplDllGsInit;
diff --git a/drivers/staging/epl/proc_fs.c b/drivers/staging/epl/proc_fs.c
index 9ccf079..e48949d 100644
--- a/drivers/staging/epl/proc_fs.c
+++ b/drivers/staging/epl/proc_fs.c
@@ -196,7 +196,7 @@ void TgtDbgSignalTracePoint(u8 bTracePointNumber_p)
 	if (bTracePointNumber_p >=
-	    (sizeof(aatmDbgTracePoint_l) / sizeof(aatmDbgTracePoint_l[0]))) {
+	    ARRAY_SIZE(aatmDbgTracePoint_l)) {
 		goto Exit;
@@ -330,7 +330,7 @@ static int EplLinProcRead(char *pcBuffer_p,
 		nSize += snprintf(pcBuffer_p + nSize, nBufferSize_p - nSize,
 				  "DbgTracePoints:\n");
 		for (nNum = 0;
-		     nNum < (sizeof(aatmDbgTracePoint_l) / sizeof(atomic_t));
+		     nNum < ARRAY_SIZE(aatmDbgTracePoint_l);
 		     nNum++) {
 			nSize +=
diff --git a/drivers/staging/line6/driver.c b/drivers/staging/line6/driver.c
index 85a20d0..f188ece 100644
--- a/drivers/staging/line6/driver.c
+++ b/drivers/staging/line6/driver.c
@@ -682,7 +682,7 @@ static int line6_probe(struct usb_interface *interface, const struct usb_device_
 		return -ENODEV;
 	/* check vendor and product id */
-	for (devtype = sizeof(line6_id_table) / sizeof(line6_id_table[0]) - 1; devtype--;)
+	for (devtype = ARRAY_SIZE(line6_id_table) - 1; devtype--;)
 		if ((le16_to_cpu(usbdev->descriptor.idVendor) == line6_id_table[devtype].idVendor) &&
 			 (le16_to_cpu(usbdev->descriptor.idProduct) == line6_id_table[devtype].idProduct))
 			break;
diff --git a/drivers/staging/meilhaus/me0600_device.h b/drivers/staging/meilhaus/me0600_device.h
index d93a8ae..75bd3b7 100644
--- a/drivers/staging/meilhaus/me0600_device.h
+++ b/drivers/staging/meilhaus/me0600_device.h
@@ -54,7 +54,7 @@ static me0600_version_t me0600_versions[] = {
 	{0},
-#define ME0600_DEVICE_VERSIONS (sizeof(me0600_versions) / sizeof(me0600_version_t) - 1)	/**< Returns the number of entries in #me0600_versions. */
+#define ME0600_DEVICE_VERSIONS (ARRAY_SIZE(me0600_versions) - 1)	/**< Returns the number of entries in #me0600_versions. */
  * @brief Returns the index of the device entry in #me0600_versions.
diff --git a/drivers/staging/meilhaus/me0900_device.h b/drivers/staging/meilhaus/me0900_device.h
index bd17f25..53c05e8 100644
--- a/drivers/staging/meilhaus/me0900_device.h
+++ b/drivers/staging/meilhaus/me0900_device.h
@@ -53,7 +53,7 @@ static me0900_version_t me0900_versions[] = {
 	{0},
-#define ME0900_DEVICE_VERSIONS (sizeof(me0900_versions) / sizeof(me0900_version_t) - 1)	/**< Returns the number of entries in #me0900_versions. */
+#define ME0900_DEVICE_VERSIONS (ARRAY_SIZE(me0900_versions) - 1)	/**< Returns the number of entries in #me0900_versions. */
  * @brief Returns the index of the device entry in #me0900_versions.
diff --git a/drivers/staging/meilhaus/me1400_device.h b/drivers/staging/meilhaus/me1400_device.h
index 6215b25..d20112d 100644
--- a/drivers/staging/meilhaus/me1400_device.h
+++ b/drivers/staging/meilhaus/me1400_device.h
@@ -60,7 +60,7 @@ static me1400_version_t me1400_versions[] = {
 	{0}
-#define ME1400_DEVICE_VERSIONS (sizeof(me1400_versions) / sizeof(me1400_version_t) - 1)	/**< Returns the number of entries in #me1400_versions. */
+#define ME1400_DEVICE_VERSIONS (ARRAY_SIZE(me1400_versions) - 1)	/**< Returns the number of entries in #me1400_versions. */
  * @brief Returns the index of the device entry in #me1400_versions.
diff --git a/drivers/staging/meilhaus/me1600_device.h b/drivers/staging/meilhaus/me1600_device.h
index f7b231f..c73aca1 100644
--- a/drivers/staging/meilhaus/me1600_device.h
+++ b/drivers/staging/meilhaus/me1600_device.h
@@ -58,7 +58,7 @@ static me1600_version_t me1600_versions[] = {
 /**< Returns the number of entries in #me1600_versions. */
-#define ME1600_DEVICE_VERSIONS (sizeof(me1600_versions) / sizeof(me1600_version_t) - 1)
+#define ME1600_DEVICE_VERSIONS (ARRAY_SIZE(me1600_versions) - 1)
  * @brief Returns the index of the device entry in #me1600_versions.
diff --git a/drivers/staging/meilhaus/me4600_device.h b/drivers/staging/meilhaus/me4600_device.h
index fa812d4..c755c57 100644
--- a/drivers/staging/meilhaus/me4600_device.h
+++ b/drivers/staging/meilhaus/me4600_device.h
@@ -80,7 +80,7 @@ static me4600_version_t me4600_versions[] = {
 	{0},
-#define ME4600_DEVICE_VERSIONS (sizeof(me4600_versions) / sizeof(me4600_version_t) - 1)	/**< Returns the number of entries in #me4600_versions. */
+#define ME4600_DEVICE_VERSIONS (ARRAY_SIZE(me4600_versions) - 1)	/**< Returns the number of entries in #me4600_versions. */
  * @brief Returns the index of the device entry in #me4600_versions.
diff --git a/drivers/staging/meilhaus/me6000_device.h b/drivers/staging/meilhaus/me6000_device.h
index 18cc7d1..eed4011 100644
--- a/drivers/staging/meilhaus/me6000_device.h
+++ b/drivers/staging/meilhaus/me6000_device.h
@@ -103,7 +103,7 @@ static me6000_version_t me6000_versions[] = {
 	{0},
-#define ME6000_DEVICE_VERSIONS (sizeof(me6000_versions) / sizeof(me6000_version_t) - 1)	/**< Returns the number of entries in #me6000_versions. */
+#define ME6000_DEVICE_VERSIONS (ARRAY_SIZE(me6000_versions) - 1)	/**< Returns the number of entries in #me6000_versions. */
  * @brief Returns the index of the device entry in #me6000_versions.
diff --git a/drivers/staging/meilhaus/me8100_device.h b/drivers/staging/meilhaus/me8100_device.h
index 44c42ef..238dc06 100644
--- a/drivers/staging/meilhaus/me8100_device.h
+++ b/drivers/staging/meilhaus/me8100_device.h
@@ -53,7 +53,7 @@ static me8100_version_t me8100_versions[] = {
 	{0},
-#define ME8100_DEVICE_VERSIONS (sizeof(me8100_versions) / sizeof(me8100_version_t) - 1)	/**< Returns the number of entries in #me8100_versions. */
+#define ME8100_DEVICE_VERSIONS (ARRAY_SIZE(me8100_versions) - 1)	/**< Returns the number of entries in #me8100_versions. */
  * @brief Returns the index of the device entry in #me8100_versions.
diff --git a/drivers/staging/meilhaus/me8200_device.h b/drivers/staging/meilhaus/me8200_device.h
index cbd2a01..66f5084 100644
--- a/drivers/staging/meilhaus/me8200_device.h
+++ b/drivers/staging/meilhaus/me8200_device.h
@@ -53,7 +53,7 @@ static me8200_version_t me8200_versions[] = {
 	{0},
-#define ME8200_DEVICE_VERSIONS (sizeof(me8200_versions) / sizeof(me8200_version_t) - 1)	/**< Returns the number of entries in #me8200_versions. */
+#define ME8200_DEVICE_VERSIONS (ARRAY_SIZE(me8200_versions) - 1)	/**< Returns the number of entries in #me8200_versions. */
  * @brief Returns the index of the device entry in #me8200_versions.
diff --git a/drivers/staging/meilhaus/metempl_device.h b/drivers/staging/meilhaus/metempl_device.h
index 3c3702c..c0626e7 100644
--- a/drivers/staging/meilhaus/metempl_device.h
+++ b/drivers/staging/meilhaus/metempl_device.h
@@ -50,7 +50,7 @@ static metempl_version_t metempl_versions[] = {
 	{0},
-#define METEMPL_DEVICE_VERSIONS (sizeof(metempl_versions) / sizeof(metempl_version_t) - 1) /**< Returns the number of entries in #metempl_versions. */
+#define METEMPL_DEVICE_VERSIONS (ARRAY_SIZE(metempl_versions) - 1) /**< Returns the number of entries in #metempl_versions. */
  * @brief Returns the index of the device entry in #metempl_versions.
diff --git a/drivers/staging/rtl8187se/r8180_wx.c b/drivers/staging/rtl8187se/r8180_wx.c
index 081c022..766892e 100644
--- a/drivers/staging/rtl8187se/r8180_wx.c
+++ b/drivers/staging/rtl8187se/r8180_wx.c
@@ -27,7 +27,7 @@
 u32 rtl8180_rates[] = {1000000,2000000,5500000,11000000,
 	6000000,9000000,12000000,18000000,24000000,36000000,48000000,54000000};
-#define RATE_COUNT (sizeof(rtl8180_rates)/sizeof(rtl8180_rates[0]))
+#define RATE_COUNT ARRAY_SIZE(rtl8180_rates)
 static CHANNEL_LIST DefaultChannelPlan[] = {
 //	{{1,2,3,4,5,6,7,8,9,10,11,12,13,14},14},			//Default channel plan
@@ -1578,9 +1578,9 @@ static struct iw_statistics *r8180_get_wireless_stats(struct net_device *dev)
 struct iw_handler_def  r8180_wx_handlers_def={
 	.standard = r8180_wx_handlers,
-	.num_standard = sizeof(r8180_wx_handlers) / sizeof(iw_handler),
+	.num_standard = ARRAY_SIZE(r8180_wx_handlers),
 	.private = r8180_private_handler,
-	.num_private = sizeof(r8180_private_handler) / sizeof(iw_handler),
+	.num_private = ARRAY_SIZE(r8180_private_handler),
  	.num_private_args = sizeof(r8180_private_args) / sizeof(struct iw_priv_args),
 	.get_wireless_stats = r8180_get_wireless_stats,
 	.private_args = (struct iw_priv_args *)r8180_private_args,
diff --git a/drivers/staging/rtl8192su/ieee80211/ieee80211_wx.c b/drivers/staging/rtl8192su/ieee80211/ieee80211_wx.c
index 3afd8b3..145a312 100644
--- a/drivers/staging/rtl8192su/ieee80211/ieee80211_wx.c
+++ b/drivers/staging/rtl8192su/ieee80211/ieee80211_wx.c
@@ -87,7 +87,7 @@ static inline char *rtl819x_translate_scan(struct ieee80211_device *ieee,
 	/* Add the protocol name */
 	iwe.cmd = SIOCGIWNAME;
-	for(i=0; i<(sizeof(ieee80211_modes)/sizeof(ieee80211_modes[0])); i++) {
+	for(i=0; i<ARRAY_SIZE(ieee80211_modes); i++) {
 		if(network->mode&(1<<i)) {
 			sprintf(pname,ieee80211_modes[i].mode_string,ieee80211_modes[i].mode_size);
 			pname +=ieee80211_modes[i].mode_size;
diff --git a/drivers/staging/rtl8192su/r8192U_wx.c b/drivers/staging/rtl8192su/r8192U_wx.c
index ad56fae..2208c9b 100644
--- a/drivers/staging/rtl8192su/r8192U_wx.c
+++ b/drivers/staging/rtl8192su/r8192U_wx.c
@@ -1221,9 +1221,9 @@ struct iw_statistics *r8192_get_wireless_stats(struct net_device *dev)
 struct iw_handler_def  r8192_wx_handlers_def={
 	.standard = r8192_wx_handlers,
-	.num_standard = sizeof(r8192_wx_handlers) / sizeof(iw_handler),
+	.num_standard = ARRAY_SIZE(r8192_wx_handlers),
 	.private = r8192_private_handler,
-	.num_private = sizeof(r8192_private_handler) / sizeof(iw_handler),
+	.num_private = ARRAY_SIZE(r8192_private_handler),
  	.num_private_args = sizeof(r8192_private_args) / sizeof(struct iw_priv_args),
 	.get_wireless_stats = r8192_get_wireless_stats,
 	.private_args = (struct iw_priv_args *)r8192_private_args,
diff --git a/drivers/staging/slicoss/slicoss.c b/drivers/staging/slicoss/slicoss.c
index b01a282..e67a130 100644
--- a/drivers/staging/slicoss/slicoss.c
+++ b/drivers/staging/slicoss/slicoss.c
@@ -1306,7 +1306,7 @@ static void slic_mcast_init_crc32(void)
 	static int p[] = { 0, 1, 2, 4, 5, 7, 8, 10, 11, 12, 16, 22, 23, 26 };
-	for (i = 0; i < sizeof(p) / sizeof(int); i++)
+	for (i = 0; i < ARRAY_SIZE(p); i++)
 		e |= 1L << (31 - p[i]);
 	for (i = 1; i < 256; i++) {
diff --git a/drivers/staging/sxg/sxg.c b/drivers/staging/sxg/sxg.c
index 3a0dac9..395e876 100644
--- a/drivers/staging/sxg/sxg.c
+++ b/drivers/staging/sxg/sxg.c
@@ -3500,7 +3500,7 @@ static void sxg_mcast_init_crc32(void)
-	for (i = 0; i < sizeof(p) / sizeof(int); i++) {
+	for (i = 0; i < ARRAY_SIZE(p); i++) {
BtrLinux
Privacy Overview
