staging: android: Replace min_t/max_t with min/max
Author: Amitoj Kaur Chawla <amitoj1606@gmail.com>
Replace min_t/max_t with min/max when both variables are of the same
type.
The Coccinelle semantic patch used to make this change is as follows:
type T;
T a,b;
- min_t(T, a, b)
+ min(a, b)
type T;
T a,b;
- max_t(T, a, b)
+ max(a, b)
Signed-off-by: Amitoj Kaur Chawla
drivers/staging/android/ashmem.c | 4 ++--
1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/staging/android/ashmem.c b/drivers/staging/android/ashmem.c
index 8ae1308..770042f 100644
--- a/drivers/staging/android/ashmem.c
+++ b/drivers/staging/android/ashmem.c
@@ -663,8 +663,8 @@ restart:
if (page_range_subsumed_by_range(range, pgstart, pgend))
return 0;
if (page_range_in_range(range, pgstart, pgend)) {
- pgstart = min_t(size_t, range->pgstart, pgstart);
- pgend = max_t(size_t, range->pgend, pgend);
+ pgstart = min(range->pgstart, pgstart);
+ pgend = max(range->pgend, pgend);
purged |= range->purged;
range_del(range);
goto restart; |
return 0;
range_del(range);
goto restart;
