Staging: agnx: Move a dereference below a NULL test
If the NULL test is necessary, then the dereference should be moved below
the NULL test.
The semantic patch that makes this change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
type T;
expression E;
identifier i,fld;
statement S;
- T i = E->fld;
+ T i;
... when != E
when != i
if (E == NULL) S
+ i = E->fld;
Signed-off-by: Julia Lawall
Cc: YanBo
drivers/staging/agnx/pci.c | 3 ++-
1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/staging/agnx/pci.c b/drivers/staging/agnx/pci.c
index 854630c..131df9f 100644
--- a/drivers/staging/agnx/pci.c
+++ b/drivers/staging/agnx/pci.c
@@ -434,11 +434,12 @@ static struct ieee80211_ops agnx_ops = {
static void __devexit agnx_pci_remove(struct pci_dev *pdev)
struct ieee80211_hw *dev = pci_get_drvdata(pdev);
- struct agnx_priv *priv = dev->priv;
+ struct agnx_priv *priv;
AGNX_TRACE;
if (!dev)
return;
+ priv = dev->priv;
ieee80211_unregister_hw(dev);
pci_iounmap(pdev, priv->ctl);
pci_iounmap(pdev, priv->data); |
AGNX_TRACE;
if (!dev)
return;
+ priv = dev->priv;
