spi/orion: Drop unnecessary null test
list_for_each_entry binds its first argument to a non-null value, and thus
any null test on the value of that argument is superfluous.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
iterator I;
expression x,E;
I(x,...) { <...
- (x != NULL) &&
  E
Signed-off-by: Julia Lawall
Signed-off-by: Grant Likely
 drivers/spi/orion_spi.c | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/spi/orion_spi.c b/drivers/spi/orion_spi.c
index 3aea50d..0b677dc 100644
--- a/drivers/spi/orion_spi.c
+++ b/drivers/spi/orion_spi.c
@@ -404,7 +404,7 @@ static int orion_spi_transfer(struct spi_device *spi, struct spi_message *m)
 			goto msg_rejected;
-		if ((t != NULL) && t->bits_per_word)
+		if (t->bits_per_word)
 			bits_per_word = t->bits_per_word;
 		if ((bits_per_word != 8) && (bits_per_word != 16)) {
@@ -415,7 +415,7 @@ static int orion_spi_transfer(struct spi_device *spi, struct spi_message *m)
 			goto msg_rejected;
 		/*make sure buffer length is even when working in 16 bit mode*/
-		if ((t != NULL) && (t->bits_per_word == 16) && (t->len & 1)) {
+		if ((t->bits_per_word == 16) && (t->len & 1)) {
 			dev_err(&spi->dev,
 				"message rejected : "
 				"odd data length (%d) while in 16 bit mode\n",
BtrLinux
Privacy Overview
