spi_s3c24xx signedness fix
Author: Matthew Wilcox <matthew@wil.cx>
On Fri, Apr 18, 2008 at 09:08:55PM +0200, Julia Lawall wrote:
> I found 63 occurrences of this problem with the following semantic match
> (http://www.emn.fr/x-info/coccinelle/):
> @@ unsigned int i; @@
> * i < 0
Since this one's always in the range 0-255, it could probably be made
signed, but it's just as easy to make it work unsigned.
Reported-by: Julia Lawall
Signed-off-by: Matthew Wilcox
Signed-off-by: David Brownell
Signed-off-by: Andrew Morton
Signed-off-by: Linus Torvalds
 drivers/spi/spi_s3c24xx.c | 6 +++---
 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/spi/spi_s3c24xx.c b/drivers/spi/spi_s3c24xx.c
index 34bfb7d..0885cc3 100644
--- a/drivers/spi/spi_s3c24xx.c
+++ b/drivers/spi/spi_s3c24xx.c
@@ -125,10 +125,10 @@ static int s3c24xx_spi_setupxfer(struct spi_device *spi,
 	/* is clk = pclk / (2 * (pre+1)), or is it
 	 *    clk = (pclk * 2) / ( pre + 1) */
-	div = (div / 2) - 1;
+	div /= 2;
-	if (div < 0)
-		div = 1;
+	if (div > 0)
+		div -= 1;
 	if (div > 255)
 		div = 255;
BtrLinux
Privacy Overview
