spi: spi-ep93xx: Fix the PTR_ERR() argument
Author: Fabio Estevam <fabio.estevam@nxp.com>
PTR_ERR should access the value just tested by IS_ERR.
The semantic patch that makes this change is available
in scripts/coccinelle/tests/odd_ptr_err.cocci.
Signed-off-by: Fabio Estevam
Signed-off-by: Mark Brown
 drivers/spi/spi-ep93xx.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/spi/spi-ep93xx.c b/drivers/spi/spi-ep93xx.c
index bb00be8..17a6387 100644
--- a/drivers/spi/spi-ep93xx.c
+++ b/drivers/spi/spi-ep93xx.c
@@ -567,7 +567,7 @@ static void ep93xx_spi_dma_transfer(struct ep93xx_spi *espi)
 	txd = ep93xx_spi_dma_prepare(espi, DMA_MEM_TO_DEV);
 	if (IS_ERR(txd)) {
 		ep93xx_spi_dma_finish(espi, DMA_DEV_TO_MEM);
-		dev_err(&espi->pdev->dev, "DMA TX failed: %ld\n", PTR_ERR(rxd));
+		dev_err(&espi->pdev->dev, "DMA TX failed: %ld\n", PTR_ERR(txd));
 		msg->status = PTR_ERR(txd);
 		return;
BtrLinux
Privacy Overview
