spi: Add helper functions for setting up transfers
Author: Lars-Peter Clausen <lars@metafoo.de>
Quite often the pattern used for setting up and transferring a synchronous SPI
transaction looks very much like the following:
	struct spi_message msg;
	struct spi_transfer xfers[] = {
	spi_message_init(&msg);
	spi_message_add_tail(&xfers[0], &msg);
	spi_message_add_tail(&xfers[ARRAY_SIZE(xfers) - 1], &msg);
	ret = spi_sync(&msg);
This patch adds two new helper functions for handling this case. The first
helper function spi_message_init_with_transfers() takes a spi_message and an
array of spi_transfers. It will initialize the message and then call
spi_message_add_tail() for each transfer in the array. E.g. the following
can be rewritten as
	spi_message_init_with_transfers(&msg, xfers, ARRAY_SIZE(xfers));
The second function spi_sync_transfer() takes a SPI device and an array of
spi_transfers. It will allocate a new spi_message (on the stack) and add all
transfers in the array to the message. Finally it will call spi_sync() on the
message.
E.g. the follwing
	ret = spi_sync(spi, &msg);
can be rewritten as
	ret = spi_sync_transfer(spi, xfers, ARRAY_SIZE(xfers));
A coccinelle script to find such instances will follow.
Signed-off-by: Lars-Peter Clausen
Reviewed-by: Mark Brown
Signed-off-by: Jonathan Cameron
 include/linux/spi/spi.h | 44 ++++++++++++++++++++++++++++++++++++++++++++
 1 file changed, 44 insertions(+)
diff --git a/include/linux/spi/spi.h b/include/linux/spi/spi.h
index f629189..7dbe586 100644
--- a/include/linux/spi/spi.h
+++ b/include/linux/spi/spi.h
@@ -591,6 +591,26 @@ spi_transfer_del(struct spi_transfer *t)
 	list_del(&t->transfer_list);
+ * spi_message_init_with_transfers - Initialize spi_message and append transfers
+ * @m: spi_message to be initialized
+ * @xfers: An array of spi transfers
+ * @num_xfers: Number of items in the xfer array
+ * This function initializes the given spi_message and adds each spi_transfer in
+ * the given array to the message.
+static inline void
+spi_message_init_with_transfers(struct spi_message *m,
+struct spi_transfer *xfers, unsigned int num_xfers)
+	unsigned int i;
+	spi_message_init(m);
+	for (i = 0; i < num_xfers; ++i)
+		spi_message_add_tail(&xfers[i], m);
 /* It's fine to embed message and transaction structures in other data
  * structures so long as you don't free them while they're in use.
@@ -683,6 +703,30 @@ spi_read(struct spi_device *spi, void *buf, size_t len)
 	return spi_sync(spi, &m);
+ * spi_sync_transfer - synchronous SPI data transfer
+ * @spi: device with which data will be exchanged
+ * @xfers: An array of spi_transfers
+ * Context: can sleep
+ * Does a synchronous SPI data transfer of the given spi_transfer array.
+ * For more specific semantics see spi_sync().
+ * It returns zero on success, else a negative error code.
+static inline int
+spi_sync_transfer(struct spi_device *spi, struct spi_transfer *xfers,
+	unsigned int num_xfers)
+	struct spi_message msg;
+	spi_message_init_with_transfers(&msg, xfers, num_xfers);
+	return spi_sync(spi, &msg);
 /* this copies txbuf and rxbuf data; for small transfers only! */
 extern int spi_write_then_read(struct spi_device *spi,
 		const void *txbuf, unsigned n_tx,
BtrLinux
Privacy Overview
