specialix.c: convert nested spin_lock_irqsave to spin_lock
If spin_lock_irqsave is called twice in a row with the same second
argument, the interrupt state at the point of the second call overwrites
the value saved by the first call.  Indeed, the second call does not
need to save the interrupt state, so it is changed to a simple
spin_lock.
The semantic match that finds this problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
expression lock1,lock2;
expression flags;
*spin_lock_irqsave(lock1,flags)
... when != flags
*spin_lock_irqsave(lock2,flags)
Signed-off-by: Julia Lawall
Signed-off-by: Alan Cox
Signed-off-by: Linus Torvalds
 drivers/char/specialix.c | 24 ++++++++++++------------
 1 file changed, 12 insertions(+), 12 deletions(-)
diff --git a/drivers/char/specialix.c b/drivers/char/specialix.c
index bfe4cdb..268e17f 100644
--- a/drivers/char/specialix.c
+++ b/drivers/char/specialix.c
@@ -1809,10 +1809,10 @@ static int sx_tiocmset(struct tty_struct *tty, struct file *file,
 		if (clear & TIOCM_DTR)
 			port->MSVR &= ~MSVR_DTR;
-	spin_lock_irqsave(&bp->lock, flags);
+	spin_lock(&bp->lock);
 	sx_out(bp, CD186x_CAR, port_No(port));
 	sx_out(bp, CD186x_MSVR, port->MSVR);
-	spin_unlock_irqrestore(&bp->lock, flags);
+	spin_unlock(&bp->lock);
 	spin_unlock_irqrestore(&port->lock, flags);
 	func_exit();
 	return 0;
@@ -1833,11 +1833,11 @@ static int sx_send_break(struct tty_struct *tty, int length)
 	port->break_length = SPECIALIX_TPS / HZ * length;
 	port->COR2 |= COR2_ETC;
 	port->IER  |= IER_TXRDY;
 	sx_out(bp, CD186x_COR2, port->COR2);
 	sx_out(bp, CD186x_IER, port->IER);
 	sx_wait_CCR(bp);
@@ -2023,9 +2023,9 @@ static void sx_unthrottle(struct tty_struct *tty)
 	if (sx_crtscts(tty))
 		port->MSVR |= MSVR_DTR;
 	/* Else clause: see remark in "sx_throttle"... */
 	if (I_IXOFF(tty)) {
 		sx_wait_CCR(bp);
@@ -2035,9 +2035,9 @@ static void sx_unthrottle(struct tty_struct *tty)
 		sx_wait_CCR(bp);
 		spin_lock_irqsave(&port->lock, flags);
 	func_exit();
@@ -2061,10 +2061,10 @@ static void sx_stop(struct tty_struct *tty)
 	port->IER &= ~IER_TXRDY;
 	func_exit();
@@ -2089,10 +2089,10 @@ static void sx_start(struct tty_struct *tty)
 	if (port->xmit_cnt && port->xmit_buf && !(port->IER & IER_TXRDY)) {
BtrLinux
Privacy Overview
