sparc: Use kmemdup rather than duplicating its implementation
Author: Thomas Meyer <thomas@m3y3r.de>
The semantic patch that makes this change is available
in scripts/coccinelle/api/memdup.cocci.
Signed-off-by: Thomas Meyer
Signed-off-by: David S. Miller
 arch/sparc/kernel/ds.c          | 6 ++----
 arch/sparc/kernel/prom_common.c | 4 +---
 2 files changed, 3 insertions(+), 7 deletions(-)
diff --git a/arch/sparc/kernel/ds.c b/arch/sparc/kernel/ds.c
index 7429b47..381edcd 100644
--- a/arch/sparc/kernel/ds.c
+++ b/arch/sparc/kernel/ds.c
@@ -1181,13 +1181,11 @@ static int __devinit ds_probe(struct vio_dev *vdev,
 	dp->rcv_buf_len = 4096;
-	dp->ds_states = kzalloc(sizeof(ds_states_template),
-				GFP_KERNEL);
+	dp->ds_states = kmemdup(ds_states_template,
+				sizeof(ds_states_template), GFP_KERNEL);
 	if (!dp->ds_states)
 		goto out_free_rcv_buf;
-	memcpy(dp->ds_states, ds_states_template,
-	       sizeof(ds_states_template));
 	dp->num_ds_states = ARRAY_SIZE(ds_states_template);
 	for (i = 0; i < dp->num_ds_states; i++)
diff --git a/arch/sparc/kernel/prom_common.c b/arch/sparc/kernel/prom_common.c
index 4661480..741df91 100644
--- a/arch/sparc/kernel/prom_common.c
+++ b/arch/sparc/kernel/prom_common.c
@@ -58,12 +58,10 @@ int of_set_property(struct device_node *dp, const char *name, void *val, int len
 	void *new_val;
 	int err;
-	new_val = kmalloc(len, GFP_KERNEL);
+	new_val = kmemdup(val, len, GFP_KERNEL);
 	if (!new_val)
 		return -ENOMEM;
-	memcpy(new_val, val, len);
 	err = -ENODEV;
 	mutex_lock(&of_set_property_mutex);
BtrLinux
Privacy Overview
