sound/soc/fsl/mpc8610_hpcd.c: add missing of_node_put
The first change is to add an of_node_put, since codec_np has previously
been allocated.  The rest of the patch reorganizes the error handling code
so the only code executed is that which is needed.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
identifier x;
expression E1!=0,E2,E3,E4;
statement S;
iterator I;
if (...) { ... when != of_node_put(x)
               when != x = E3
               when != E3 = x
*  return ...;
... when != x = E2
    when != I(...,x,...) S
if (...) { ... when != x = E4
 of_node_put(x); ... return ...; }
Signed-off-by: Julia Lawall
Acked-by: Timur Tabi
Acked-by: Liam Girdwood
Signed-off-by: Mark Brown
 sound/soc/fsl/mpc8610_hpcd.c | 18 +++++++++---------
 1 file changed, 9 insertions(+), 9 deletions(-)
diff --git a/sound/soc/fsl/mpc8610_hpcd.c b/sound/soc/fsl/mpc8610_hpcd.c
index a192979..358f0ba 100644
--- a/sound/soc/fsl/mpc8610_hpcd.c
+++ b/sound/soc/fsl/mpc8610_hpcd.c
@@ -345,8 +345,10 @@ static int mpc8610_hpcd_probe(struct platform_device *pdev)
 	machine_data = kzalloc(sizeof(struct mpc8610_hpcd_data), GFP_KERNEL);
-	if (!machine_data)
-		return -ENOMEM;
+	if (!machine_data) {
+		ret = -ENOMEM;
+		goto error_alloc;
 	machine_data->dai[0].cpu_dai_name = dev_name(&ssi_pdev->dev);
 	machine_data->dai[0].ops = &mpc8610_hpcd_ops;
@@ -494,7 +496,7 @@ static int mpc8610_hpcd_probe(struct platform_device *pdev)
 	ret = platform_device_add(sound_device);
 	if (ret) {
 		dev_err(&pdev->dev, "platform device add failed\n");
-		goto error;
+		goto error_sound;
 	dev_set_drvdata(&pdev->dev, sound_device);
@@ -502,14 +504,12 @@ static int mpc8610_hpcd_probe(struct platform_device *pdev)
 	return 0;
+error_sound:
+	platform_device_unregister(sound_device);
 error:
-	of_node_put(codec_np);
-	if (sound_device)
-		platform_device_unregister(sound_device);
 	kfree(machine_data);
+error_alloc:
+	of_node_put(codec_np);
 	return ret;
BtrLinux
Privacy Overview
