sound/oss/opl3: Remove typedef opl_devinfo
Author: Himangi Saraogi <himangi774@gmail.com>
This typedef is unnecessary and should just be removed as they are
never used.
The following Coccinelle semantic patch detects the case.
@tn@
identifier i;
type td;
-typedef
 struct i { ... }
-td
type tn.td;
identifier tn.i;
-td
+ struct i
Signed-off-by: Himangi Saraogi
Acked-by: Julia Lawall
Signed-off-by: Takashi Iwai
 sound/oss/opl3.c | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/sound/oss/opl3.c b/sound/oss/opl3.c
index 4709e59..607cee4 100644
--- a/sound/oss/opl3.c
+++ b/sound/oss/opl3.c
@@ -52,7 +52,7 @@ struct voice_info
 	int             panning;	/* 0xffff means not set */
-typedef struct opl_devinfo
+struct opl_devinfo
 	int             base;
 	int             left_io, right_io;
@@ -73,7 +73,7 @@ typedef struct opl_devinfo
 	unsigned char   cmask;
 	int             is_opl4;
-} opl_devinfo;
 static struct opl_devinfo *devc = NULL;
BtrLinux
Privacy Overview
