sound: Use BUG_ON
if (...) BUG(); should be replaced with BUG_ON(...) when the test has no
side-effects to allow a definition of BUG_ON that drops the code completely.
The semantic patch that makes this change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@ disable unlikely @ expression E,f; @@
  if (<... f(...) ...>) { BUG(); }
- if (unlikely(E)) { BUG(); }
+ BUG_ON(E);
@@ expression E,f; @@
- if (E) { BUG(); }
+ BUG_ON(E);
Signed-off-by: Julia Lawall
Signed-off-by: Andrew Morton
 sound/oss/trident.c | 12 ++++--------
 1 file changed, 4 insertions(+), 8 deletions(-)
diff --git a/sound/oss/trident.c b/sound/oss/trident.c
index d6af906..f43f91e 100644
--- a/sound/oss/trident.c
+++ b/sound/oss/trident.c
@@ -3076,8 +3076,7 @@ ali_ac97_get(struct trident_card *card, int secondary, u8 reg)
 	u16 wcontrol;
 	unsigned long flags;
-	if (!card)
-		BUG();
+	BUG_ON(!card);
 	address = ALI_AC97_READ;
 	if (card->revision == ALI_5451_V02) {
@@ -3148,8 +3147,7 @@ ali_ac97_set(struct trident_card *card, int secondary, u8 reg, u16 val)
 	data = ((u32) val) << 16;
-	if (!card)
-		BUG();
+	BUG_ON(!card);
 	address = ALI_AC97_WRITE;
 	mask = ALI_AC97_WRITE_ACTION | ALI_AC97_AUDIO_BUSY;
@@ -3213,8 +3211,7 @@ ali_ac97_read(struct ac97_codec *codec, u8 reg)
 	struct trident_card *card = NULL;
 	/* Added by Matt Wu */
-	if (!codec)
-		BUG();
+	BUG_ON(!codec);
 	card = (struct trident_card *) codec->private_data;
@@ -3240,8 +3237,7 @@ ali_ac97_write(struct ac97_codec *codec, u8 reg, u16 val)
 	struct trident_card *card;
-	if (!codec)
-		BUG();
+	BUG_ON(!codec);
BtrLinux
Privacy Overview
