sound/oss/waveartist.c | 157 ++++++++++++++++++++++++++++---------------------
1 file changed, 89 insertions(+), 68 deletions(-)
diff --git a/sound/oss/waveartist.c b/sound/oss/waveartist.c
index 672af8b..b36ea47 100644
--- a/sound/oss/waveartist.c
+++ b/sound/oss/waveartist.c
@@ -92,7 +92,7 @@ static unsigned short levels[SOUND_MIXER_NRDEVICES] = {
0x0000 /* Monitor */
-typedef struct {
+struct wavnc_info {
struct address_info hw; /* hardware */
char *chip_name;
@@ -119,7 +119,7 @@ typedef struct {
unsigned int line_mute_state :1;/* set by ioctl or autoselect */
unsigned int use_slider :1;/* use slider setting for o/p vol */
#endif
-} wavnc_info;
* This is the implementation specific mixer information.
@@ -129,29 +129,30 @@ struct waveartist_mixer_info {
unsigned int recording_devs; /* Recordable devies */
unsigned int stereo_devs; /* Stereo devices */
- unsigned int (*select_input)(wavnc_info *, unsigned int,
+ unsigned int (*select_input)(struct wavnc_info *, unsigned int,
unsigned char *, unsigned char *);
- int (*decode_mixer)(wavnc_info *, int,
+ int (*decode_mixer)(struct wavnc_info *, int,
unsigned char, unsigned char);
- int (*get_mixer)(wavnc_info *, int);
+ int (*get_mixer)(struct wavnc_info *, int);
-typedef struct wavnc_port_info {
+struct wavnc_port_info {
int open_mode;
int speed;
int channels;
int audio_format;
-} wavnc_port_info;
static int nr_waveartist_devs;
-static wavnc_info adev_info[MAX_AUDIO_DEV];
+static struct wavnc_info adev_info[MAX_AUDIO_DEV];
static DEFINE_SPINLOCK(waveartist_lock);
#ifndef CONFIG_ARCH_NETWINDER
#define machine_is_netwinder() 0
#else
static struct timer_list vnc_timer;
-static void vnc_configure_mixer(wavnc_info *devc, unsigned int input_mask);
+static void vnc_configure_mixer(struct wavnc_info *devc,
+ unsigned int input_mask);
static int vnc_private_ioctl(int dev, unsigned int cmd, int __user *arg);
static void vnc_slider_tick(unsigned long data);
#endif
@@ -169,7 +170,7 @@ waveartist_set_ctlr(struct address_info *hw, unsigned char clear, unsigned char
/* Toggle IRQ acknowledge line
static inline void
-waveartist_iack(wavnc_info *devc)
+waveartist_iack(struct wavnc_info *devc)
unsigned int ctlr_port = devc->hw.io_base + CTLR;
int old_ctlr;
@@ -188,7 +189,7 @@ waveartist_sleep(int timeout_ms)
static int
-waveartist_reset(wavnc_info *devc)
+waveartist_reset(struct wavnc_info *devc)
struct address_info *hw = &devc->hw;
unsigned int timeout, res = -1;
@@ -223,7 +224,7 @@ waveartist_reset(wavnc_info *devc)
* and can send or receive multiple words.
static int
-waveartist_cmd(wavnc_info *devc,
+waveartist_cmd(struct wavnc_info *devc,
int nr_cmd, unsigned int *cmd,
int nr_resp, unsigned int *resp)
@@ -299,7 +300,7 @@ waveartist_cmd(wavnc_info *devc,
* Send one command word
static inline int
-waveartist_cmd1(wavnc_info *devc, unsigned int cmd)
+waveartist_cmd1(struct wavnc_info *devc, unsigned int cmd)
return waveartist_cmd(devc, 1, &cmd, 0, NULL);
@@ -308,7 +309,7 @@ waveartist_cmd1(wavnc_info *devc, unsigned int cmd)
* Send one command, receive one word
static inline unsigned int
-waveartist_cmd1_r(wavnc_info *devc, unsigned int cmd)
+waveartist_cmd1_r(struct wavnc_info *devc, unsigned int cmd)
unsigned int ret;
@@ -322,7 +323,7 @@ waveartist_cmd1_r(wavnc_info *devc, unsigned int cmd)
* word (and throw it away)
static inline int
-waveartist_cmd2(wavnc_info *devc, unsigned int cmd, unsigned int arg)
+waveartist_cmd2(struct wavnc_info *devc, unsigned int cmd, unsigned int arg)
unsigned int vals[2];
@@ -336,7 +337,7 @@ waveartist_cmd2(wavnc_info *devc, unsigned int cmd, unsigned int arg)
* Send a triple command
static inline int
-waveartist_cmd3(wavnc_info *devc, unsigned int cmd,
+waveartist_cmd3(struct wavnc_info *devc, unsigned int cmd,
unsigned int arg1, unsigned int arg2)
unsigned int vals[3];
@@ -349,7 +350,7 @@ waveartist_cmd3(wavnc_info *devc, unsigned int cmd,
static int
-waveartist_getrev(wavnc_info *devc, char *rev)
+waveartist_getrev(struct wavnc_info *devc, char *rev)
unsigned int temp[2];
unsigned int cmd = WACMD_GETREV;
@@ -371,15 +372,15 @@ static void waveartist_trigger(int dev, int state);
static int
waveartist_open(int dev, int mode)
- wavnc_info *devc;
- wavnc_port_info *portc;
+ struct wavnc_info *devc;
+ struct wavnc_port_info *portc;
unsigned long flags;
if (dev < 0 || dev >= num_audiodevs)
return -ENXIO;
- devc = (wavnc_info *) audio_devs[dev]->devc;
- portc = (wavnc_port_info *) audio_devs[dev]->portc;
+ devc = (struct wavnc_info *) audio_devs[dev]->devc;
+ portc = (struct wavnc_port_info *) audio_devs[dev]->portc;
spin_lock_irqsave(&waveartist_lock, flags);
if (portc->open_mode || (devc->open_mode & mode)) {
@@ -404,8 +405,10 @@ waveartist_open(int dev, int mode)
static void
waveartist_close(int dev)
- wavnc_info *devc = (wavnc_info *) audio_devs[dev]->devc;
- wavnc_port_info *portc = (wavnc_port_info *) audio_devs[dev]->portc;
+ struct wavnc_info *devc = (struct wavnc_info *)
+ audio_devs[dev]->devc;
+ struct wavnc_port_info *portc = (struct wavnc_port_info *)
+ audio_devs[dev]->portc;
@@ -422,8 +425,10 @@ waveartist_close(int dev)
static void
waveartist_output_block(int dev, unsigned long buf, int __count, int intrflag)
unsigned int count = __count;
@@ -467,8 +472,10 @@ waveartist_output_block(int dev, unsigned long buf, int __count, int intrflag)
static void
waveartist_start_input(int dev, unsigned long buf, int __count, int intrflag)
@@ -514,7 +521,7 @@ waveartist_ioctl(int dev, unsigned int cmd, void __user * arg)
static unsigned int
-waveartist_get_speed(wavnc_port_info *portc)
+waveartist_get_speed(struct wavnc_port_info *portc)
unsigned int speed;
@@ -542,7 +549,7 @@ waveartist_get_speed(wavnc_port_info *portc)
static unsigned int
-waveartist_get_bits(wavnc_port_info *portc)
+waveartist_get_bits(struct wavnc_port_info *portc)
unsigned int bits;
@@ -560,8 +567,10 @@ static int
waveartist_prepare_for_input(int dev, int bsize, int bcount)
unsigned int speed, bits;
if (devc->audio_mode)
@@ -615,8 +624,10 @@ static int
waveartist_prepare_for_output(int dev, int bsize, int bcount)
@@ -660,8 +671,9 @@ waveartist_prepare_for_output(int dev, int bsize, int bcount)
static void
waveartist_halt(int dev)
- wavnc_info *devc;
if (portc->open_mode & OPEN_WRITE)
waveartist_halt_output(dev);
@@ -669,14 +681,15 @@ waveartist_halt(int dev)
if (portc->open_mode & OPEN_READ)
waveartist_halt_input(dev);
devc->audio_mode = 0;
static void
waveartist_halt_input(int dev)
@@ -703,7 +716,8 @@ waveartist_halt_input(int dev)
static void
waveartist_halt_output(int dev)
@@ -727,8 +741,10 @@ waveartist_halt_output(int dev)
static void
if (debug_flg & DEBUG_TRIGGER) {
@@ -764,7 +780,8 @@ waveartist_trigger(int dev, int state)
static int
waveartist_set_speed(int dev, int arg)
if (arg <= 0)
return portc->speed;
@@ -782,7 +799,8 @@ waveartist_set_speed(int dev, int arg)
static short
waveartist_set_channels(int dev, short arg)
if (arg != 1 && arg != 2)
return portc->channels;
@@ -794,7 +812,8 @@ waveartist_set_channels(int dev, short arg)
static unsigned int
waveartist_set_bits(int dev, unsigned int arg)
if (arg == 0)
return portc->audio_format;
@@ -829,7 +848,7 @@ static struct audio_driver waveartist_audio_driver = {
static irqreturn_t
waveartist_intr(int irq, void *dev_id)
- wavnc_info *devc = dev_id;
+ struct wavnc_info *devc = dev_id;
int irqstatus, status;
spin_lock(&waveartist_lock);
@@ -912,7 +931,7 @@ static const struct mix_ent mix_devs[SOUND_MIXER_NRDEVICES] = {
static void
-waveartist_mixer_update(wavnc_info *devc, int whichDev)
+waveartist_mixer_update(struct wavnc_info *devc, int whichDev)
unsigned int lev_left, lev_right;
@@ -973,7 +992,8 @@ waveartist_mixer_update(wavnc_info *devc, int whichDev)
* relevant *_select_input function has done that for us.
static void
-waveartist_set_adc_mux(wavnc_info *devc, char left_dev, char right_dev)
+waveartist_set_adc_mux(struct wavnc_info *devc, char left_dev,
+ char right_dev)
unsigned int reg_08, reg_09;
@@ -996,7 +1016,7 @@ waveartist_set_adc_mux(wavnc_info *devc, char left_dev, char right_dev)
* SOUND_MASK_MIC Mic Microphone
static unsigned int
-waveartist_select_input(wavnc_info *devc, unsigned int recmask,
+waveartist_select_input(struct wavnc_info *devc, unsigned int recmask,
unsigned char *dev_l, unsigned char *dev_r)
unsigned int recdev = ADC_MUX_NONE;
@@ -1024,7 +1044,8 @@ waveartist_select_input(wavnc_info *devc, unsigned int recmask,
static int
-waveartist_decode_mixer(wavnc_info *devc, int dev, unsigned char lev_l,
+waveartist_decode_mixer(struct wavnc_info *devc, int dev,
+ unsigned char lev_l,
unsigned char lev_r)
switch (dev) {
@@ -1050,7 +1071,7 @@ waveartist_decode_mixer(wavnc_info *devc, int dev, unsigned char lev_l,
return dev;
-static int waveartist_get_mixer(wavnc_info *devc, int dev)
+static int waveartist_get_mixer(struct wavnc_info *devc, int dev)
return devc->levels[dev];
@@ -1068,7 +1089,7 @@ static const struct waveartist_mixer_info waveartist_mixer = {
static void
-waveartist_set_recmask(wavnc_info *devc, unsigned int recmask)
+waveartist_set_recmask(struct wavnc_info *devc, unsigned int recmask)
unsigned char dev_l, dev_r;
@@ -1092,7 +1113,7 @@ waveartist_set_recmask(wavnc_info *devc, unsigned int recmask)
static int
-waveartist_set_mixer(wavnc_info *devc, int dev, unsigned int level)
+waveartist_set_mixer(struct wavnc_info *devc, int dev, unsigned int level)
unsigned int lev_left = level & 0x00ff;
unsigned int lev_right = (level & 0xff00) >> 8;
@@ -1120,7 +1141,7 @@ waveartist_set_mixer(wavnc_info *devc, int dev, unsigned int level)
static int
waveartist_mixer_ioctl(int dev, unsigned int cmd, void __user * arg)
- wavnc_info *devc = (wavnc_info *)audio_devs[dev]->devc;
+ struct wavnc_info *devc = (struct wavnc_info *)audio_devs[dev]->devc;
int ret = 0, val, nr;
@@ -1204,7 +1225,7 @@ static struct mixer_operations waveartist_mixer_operations =
static void
-waveartist_mixer_reset(wavnc_info *devc)
+waveartist_mixer_reset(struct wavnc_info *devc)
int i;
@@ -1241,9 +1262,9 @@ waveartist_mixer_reset(wavnc_info *devc)
waveartist_mixer_update(devc, i);
-static int __init waveartist_init(wavnc_info *devc)
+static int __init waveartist_init(struct wavnc_info *devc)
char rev[3], dev_name[64];
int my_dev;
@@ -1261,7 +1282,7 @@ static int __init waveartist_init(wavnc_info *devc)
conf_printf2(dev_name, devc->hw.io_base, devc->hw.irq,
devc->hw.dma, devc->hw.dma2);
- portc = kzalloc(sizeof(wavnc_port_info), GFP_KERNEL);
+ portc = kzalloc(sizeof(struct wavnc_port_info), GFP_KERNEL);
if (portc == NULL)
goto nomem;
@@ -1330,7 +1351,7 @@ nomem:
static int __init probe_waveartist(struct address_info *hw_config)
- wavnc_info *devc = &adev_info[nr_waveartist_devs];
+ struct wavnc_info *devc = &adev_info[nr_waveartist_devs];
if (nr_waveartist_devs >= MAX_AUDIO_DEV) {
printk(KERN_WARNING "waveartist: too many audio devices\n");
@@ -1367,7 +1388,7 @@ static int __init probe_waveartist(struct address_info *hw_config)
static void __init
attach_waveartist(struct address_info *hw, const struct waveartist_mixer_info *mix)
* NOTE! If irq < 0, there is another driver which has allocated the
@@ -1410,7 +1431,7 @@ attach_waveartist(struct address_info *hw, const struct waveartist_mixer_info *m
static void __exit unload_waveartist(struct address_info *hw)
- wavnc_info *devc = NULL;
+ struct wavnc_info *devc = NULL;
int i;
for (i = 0; i < nr_waveartist_devs; i++)
@@ -1478,7 +1499,7 @@ static void __exit unload_waveartist(struct address_info *hw)
#define VNC_DISABLE_AUTOSWITCH 0x80
static inline void
-vnc_mute_spkr(wavnc_info *devc)
+vnc_mute_spkr(struct wavnc_info *devc)
@@ -1488,7 +1509,7 @@ vnc_mute_spkr(wavnc_info *devc)
static void
-vnc_mute_lout(wavnc_info *devc)
+vnc_mute_lout(struct wavnc_info *devc)
unsigned int left, right;
@@ -1507,7 +1528,7 @@ vnc_mute_lout(wavnc_info *devc)
static int
-vnc_volume_slider(wavnc_info *devc)
+vnc_volume_slider(struct wavnc_info *devc)
static signed int old_slider_volume;
@@ -1567,7 +1588,7 @@ vnc_volume_slider(wavnc_info *devc)
* SOUND_MASK_MIC Right Mic Builtin microphone
static unsigned int
-netwinder_select_input(wavnc_info *devc, unsigned int recmask,
+netwinder_select_input(struct wavnc_info *devc, unsigned int recmask,
unsigned int recdev_l = ADC_MUX_NONE, recdev_r = ADC_MUX_NONE;
@@ -1604,7 +1625,7 @@ netwinder_select_input(wavnc_info *devc, unsigned int recmask,
static int
-netwinder_decode_mixer(wavnc_info *devc, int dev, unsigned char lev_l,
+netwinder_decode_mixer(struct wavnc_info *devc, int dev, unsigned char lev_l,
switch (dev) {
@@ -1643,7 +1664,7 @@ netwinder_decode_mixer(wavnc_info *devc, int dev, unsigned char lev_l,
return dev;
-static int netwinder_get_mixer(wavnc_info *devc, int dev)
+static int netwinder_get_mixer(struct wavnc_info *devc, int dev)
int levels;
@@ -1703,7 +1724,7 @@ static const struct waveartist_mixer_info netwinder_mixer = {
static void
-vnc_configure_mixer(wavnc_info *devc, unsigned int recmask)
+vnc_configure_mixer(struct wavnc_info *devc, unsigned int recmask)
if (!devc->no_autoselect) {
if (devc->handset_detect) {
@@ -1729,7 +1750,7 @@ vnc_configure_mixer(wavnc_info *devc, unsigned int recmask)
static int
-vnc_slider(wavnc_info *devc)
+vnc_slider(struct wavnc_info *devc)
signed int slider_volume;
unsigned int temp, old_hs, old_td;
@@ -1795,7 +1816,7 @@ vnc_slider_tick(unsigned long data)
static int
vnc_private_ioctl(int dev, unsigned int cmd, int __user * arg)
int val;
switch (cmd) { |
