sound: aedsp16: Change structure initialisation to C99 style
Author: Amitoj Kaur Chawla <amitoj1606@gmail.com>
Replace the in order struct initialisation style with explicit field
style.
The Coccinelle semantic patch used to make this change is as follows:
@decl@
identifier i1,fld;
type T;
field list[n] fs;
struct i1 {
 fs
 T fld;
identifier decl.i1,i2,decl.fld;
expression e;
position bad.p, bad.fix;
struct i1 i2@p = { ...,
+ .fld = e
- e@fix
Signed-off-by: Amitoj Kaur Chawla
Signed-off-by: Takashi Iwai
 sound/oss/aedsp16.c | 14 +++++++-------
 1 file changed, 7 insertions(+), 7 deletions(-)
diff --git a/sound/oss/aedsp16.c b/sound/oss/aedsp16.c
index 35b5912..bb477d5 100644
--- a/sound/oss/aedsp16.c
+++ b/sound/oss/aedsp16.c
@@ -482,13 +482,13 @@ static struct orVals orDMA[] __initdata = {
 static struct aedsp16_info ae_config = {
-	DEF_AEDSP16_IOB,
-	DEF_AEDSP16_IRQ,
-	DEF_AEDSP16_MRQ,
-	DEF_AEDSP16_DMA,
-	-1,
-	-1,
-	INIT_NONE
+	.base_io = DEF_AEDSP16_IOB,
+	.irq = DEF_AEDSP16_IRQ,
+	.mpu_irq = DEF_AEDSP16_MRQ,
+	.dma = DEF_AEDSP16_DMA,
+	.mss_base = -1,
+	.mpu_base = -1,
+	.init = INIT_NONE
BtrLinux
Privacy Overview
