sony-laptop: Fix handling sony_nc_hotkeys_decode result
Author: Andrzej Hajda <a.hajda@samsung.com>
sony_nv_hotkeys_decode can return a negative value. real_ev is a u32 variable.
The check for real_ev > 0 is incorrect.
Use an intermediate ret variable.
The problem has been detected using proposed semantic patch
scripts/coccinelle/tests/assign_signed_to_unsigned.cocci [1].
[1]: http://permalink.gmane.org/gmane.linux.kernel/2046107
Signed-off-by: Andrzej Hajda
[dvhart: clarify commit msg, drop superfluous else block]
Signed-off-by: Darren Hart
 drivers/platform/x86/sony-laptop.c | 13 +++++++------
 1 file changed, 7 insertions(+), 6 deletions(-)
diff --git a/drivers/platform/x86/sony-laptop.c b/drivers/platform/x86/sony-laptop.c
index aeb80d1..f73c295 100644
--- a/drivers/platform/x86/sony-laptop.c
+++ b/drivers/platform/x86/sony-laptop.c
@@ -1204,6 +1204,8 @@ static void sony_nc_notify(struct acpi_device *device, u32 event)
 	u32 real_ev = event;
 	u8 ev_type = 0;
+	int ret;
 	dprintk("sony_nc_notify, event: 0x%.2x\n", event);
 	if (event >= 0x90) {
@@ -1225,13 +1227,12 @@ static void sony_nc_notify(struct acpi_device *device, u32 event)
 		case 0x0100:
 		case 0x0127:
 			ev_type = HOTKEY;
-			real_ev = sony_nc_hotkeys_decode(event, handle);
+			ret = sony_nc_hotkeys_decode(event, handle);
-			if (real_ev > 0)
-				sony_laptop_report_input_event(real_ev);
-			else
-				/* restore the original event for reporting */
-				real_ev = event;
+			if (ret > 0) {
+				sony_laptop_report_input_event(ret);
+				real_ev = ret;
 			break;
BtrLinux
Privacy Overview
