smsc: replace IS_ERR and PTR_ERR with PTR_ERR_OR_ZERO
Author: Duan Jiong <duanj.fnst@cn.fujitsu.com>
This patch fixes coccinelle error regarding usage of IS_ERR and
PTR_ERR instead of PTR_ERR_OR_ZERO.
Signed-off-by: Duan Jiong
Signed-off-by: David S. Miller
 drivers/net/ethernet/smsc/smc9194.c | 4 +---
 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/drivers/net/ethernet/smsc/smc9194.c b/drivers/net/ethernet/smsc/smc9194.c
index 51aa9cf..4092fed 100644
--- a/drivers/net/ethernet/smsc/smc9194.c
+++ b/drivers/net/ethernet/smsc/smc9194.c
@@ -1569,9 +1569,7 @@ int __init init_module(void)
 	/* copy the parameters from insmod into the device structure */
 	devSMC9194 = smc_init(-1);
-	if (IS_ERR(devSMC9194))
-		return PTR_ERR(devSMC9194);
-	return 0;
+	return PTR_ERR_OR_ZERO(devSMC9194);
 void __exit cleanup_module(void)
BtrLinux
Privacy Overview
